ᐅ Why do some Billy doors no longer fit after moving?
Created on: 14 Apr 2021 08:37
Kapi49
Kapi49
14 Apr 2021 08:37
Why do some Billy cabinet doors no longer fit properly after moving? I recently took my Billy shelves with me to use them in my new apartment. The matching doors, which previously fit perfectly, now either stick at the hinges or do not slide properly in the tracks. I am particularly interested in how factors such as shelf alignment, indoor climate, or structural changes might affect this. Are there common reasons why doors that once fit perfectly suddenly do not open or close properly anymore? I look forward to your experiences and well-founded explanations!
FLOBAU
14 Apr 2021 10:12
The issue usually relates to dimensional accuracy, which can be affected by various factors during relocation. Firstly, wooden parts often warp due to changes in humidity and temperature, which can cause slight deformations, especially in particleboard or MDF furniture with laminate surfaces like Billy shelves. Secondly, small variations when positioning the shelf are critical: if the shelf is not set perfectly straight in the new room (neither horizontally nor vertically), the doors can catch at certain contact points.
In addition, changes in floor unevenness and wall straightness play a role. The door attachment points depend on the side panels of the shelf. If the shelf has slightly warped during transport or assembly, the door will no longer fit precisely on the hinges or sliding tracks.
In conclusion: Check the alignment of the entire piece of furniture, adjust the doors using the adjustment screws, and consider environmental factors such as humidity. This usually resolves the problem.
eldubi
14 Apr 2021 10:39
Shelf shifted or warped during transport. Humidity has affected the material. Doors need to be realigned.
LOJOPAR
15 Apr 2021 09:47
Here is a structured brief explanation of the problem "Why don’t Billy doors fit properly after moving?":
1. Material expansion: Chipboard and MDF react to moisture, causing slight dimensional changes.
2. Assembly accuracy: When disassembling and reassembling, screws may not be tightened exactly the same way, which can lead to small deviations.
3. Uneven floors and walls: In the new home, walls or floors may no longer be perfectly level, so the unit may not stand completely plumb.
4. Door adjustment: The doors have small adjustment options on the hinges. These should be precisely readjusted during refitting after the move.
Tip: Use a spirit level to check the shelving unit and adjust the doors using the small thumb wheel on the hinges. If needed, you can also stick felt pads under the feet of the unit to improve stability.
FLOBAU schrieb:
If the unit is not perfectly level in the new room... the doors can catch on symbolic contact points.
Exactly! A difference of just a few millimeters often makes all the difference here.
V
vinpau
15 Apr 2021 11:03
I totally understand! After my move, my Billy cabinet doors also initially protested and wouldn’t open properly. 🙂 But with a bit of patience and some adjustments to the hinges, it was really easy to fix! Just loosen the screws slightly, shift the doors a bit, and then tighten everything again.
Exactly! And remember: small changes in humidity can significantly affect wood-based materials. So don’t worry, you’ll definitely manage it! 🙂
Kapi49
16 Apr 2021 07:49
Thank you for the many valuable insights! I found the advice on material expansion and the effect of the shelf orientation especially helpful.
LOJOPAR schrieb:
Check the shelf with a spirit level and adjust the doors using the small knurled wheel on the hinges.
I will definitely try that and also consider the option of using felt pads. During transport, I handled the shelf carefully as recommended, but slight warping can of course still occur.
If anyone has tips on how exactly to adjust the doors or if any special tools are needed, I would appreciate further advice!
