When moving, I noticed that the Billy cabinet doors from the IKEA range, which we previously used without any issues, no longer fit properly in the new apartment. Specifically, the doors don’t close flush anymore or sometimes can’t be fully closed at all. I suspect this might be related to changes in the room geometry or the frame construction, but I’m not certain.
My question to you: Why do some BILLY doors no longer fit correctly after moving? Could it be due to differences in the walls, the installation, or possibly technical details of the doors themselves? Are there common causes to check before potentially damaging the doors or trying to force them into position?
Looking forward to your insights and solutions!
lume42 schrieb:
Why don’t some BILLY doors fit properly after moving?This is often due to slight dimensional differences between rooms. Walls are never perfectly straight. First, check if the cabinet carcass is level and that the door hinges are properly adjusted.
SETHBLA schrieb:
Walls are never perfectly straight.This is a very important point that should not be underestimated. The BILLY shelves and their doors are designed for standardized, mostly straight walls and angles. However, after moving—especially into an older apartment or a building with uneven wall surfaces—small deviations of just a few millimeters at several points can be enough to prevent the doors from closing properly.
Several factors come into play here: the frames of the BILLY cabinet have standardized dimensions that may no longer fit the conditions of the new wall perfectly after a move. In addition, the floor or wall are often not completely level or vertical. These small differences add up and cause the doors to sit crooked or stick.
To solve this issue, the doors can be adjusted multiple times using the hinges. IKEA has built in a five-way adjustment mechanism that allows fine-tuning along the X, Y, and Z axes. Often this is not enough if the cabinet itself is already slightly out of alignment.
In that case, the cabinet body should be checked and, if necessary, leveled, for example by placing shims under the back panel or small wedges on the floor. I also wonder: has anyone had experience with whether the wood of the BILLY shelves warps slightly due to changes in humidity? This could be relevant when moving between more humid and drier apartments. I would be interested to hear if anyone has concrete insights on this.
deoke schrieb:
BILLY cabinets are designed for standardized, mostly flat walls.Exactly, that's why you always need to check if the cabinet is truly straight and stable. Otherwise, the doors will jam. It's best to fully disassemble the cabinet and realign it.
I find it interesting that people often immediately point to wall unevenness and dimensional discrepancies without considering how precise the fit of the doors actually was in the old apartment.
Was the door fit thoroughly checked beforehand? Maybe the tolerance limits were already stretched in the old apartment, and moving just reveals these issues.
Also: Who can guarantee that the material hasn’t slightly warped over time? Another possibility is that small damages or misalignments occurred during transport, causing the problems. It’s worth critically examining these factors as well before focusing solely on the wall conditions.
lume42 schrieb:
... the doors no longer close flush or cannot be fully closed at all.
dinano schrieb:
Perhaps the tolerance limits were already stretched in the old apartment, and the move just brought these shortcomings to light.That’s a reasonable approach. Objectively, the doors and carcasses of BILLY are designed to standard dimensions. However, there are always manufacturing tolerances, which for IKEA furniture typically lie within the millimeter range. Walls in older buildings, on the other hand, are often not perfectly square or plumb.
In practice, this frequently leads to combinations that cause door issues despite minimal deviations in internal dimensions. It is recommended to use a spirit level to check the cabinet’s alignment and, if necessary, adjust the hinges. Some people also use a file to slightly modify edges—but this should be done with caution.
Basically, it is a mix of manufacturing and construction tolerances that cause fitting problems when furniture is reassembled during a move.
