Hello everyone, I recently moved and wanted to reuse my Billy shelves, but the doors no longer fit properly on the new unit. The frames seem to be slightly altered or warped, the doors don’t fully close and sometimes get stuck. My question is: Why do some Billy doors not fit after a move, even though it is exactly the same model? I have already checked the measurements, and they appear to be identical. Could there be manufacturing tolerances, deformations, or other reasons that might cause this? I would appreciate a technical explanation and possible solutions, thanks!
Hello Dosau2,
Very interesting question, which can have several causes. Basically, you need to know that Billy shelves are standardized, but there are certain tolerances in the manufacturing and assembly of the doors and side panels. The material also plays an important role. The Billy doors are usually made of engineered wood panels, which are sensitive to moisture and temperature fluctuations. Even slight swelling of the materials caused by humidity or temperature changes can cause the doors to warp and no longer fit precisely in the frame gap.
Furthermore, during a move, slight mechanical stresses, deformations, or adjustments to the hinges can occur. The hinges are adjustable, but if they are not mounted centrally or at the correct angle, misalignment can easily happen. The shelf frame at the new location might also be slightly uneven or not completely flat, which affects the door fit.
Another issue is how the doors were installed. It may be that old screw holes or signs of wear cause the door to no longer fit exactly. A question for you: Did you completely disassemble the doors and reassemble them at the new location, or did you just move them and put them back in place? Are the hinges still the original ones, and were they mounted in the same original positions?
First, I would recommend carefully measuring the doors and hinges and realigning the hinges. Small adjustments around the door frames may also be necessary, such as fine sanding to achieve precise gaps. You should also check the wood moisture content, as glued or warped material is difficult to fix.
I hope this helps as an initial overview! 🙂
Hello Dosau2, I can relate to your situation; it happens more often than you might think. The Billy shelves often feel a bit different in a new location because they are not entirely made of metal but of particleboard, which can react to changes in the environment.
I recommend carefully checking the doors and hinges and, most importantly, tightening the screws, as they can sometimes loosen and cause misalignment. Also, a slight adjustment with the hinges often helps a lot. Don’t hesitate to gently sand the door frame with fine sandpaper if there is too much material in the contact points interfering with the new installation.
Don’t be discouraged; this is usually easy to fix with Billy shelves! 🙂
Laukau5 schrieb:That's true, especially during transport — for example, if the shelf was stored in a basement with high humidity and is now placed in a warmer living space, the material can behave differently.
That the doors can warp due to moisture and temperature changes
Hello Dosau2,
I would like to approach the topic from a slightly different technical perspective. With Billy shelves, even though they are mass-produced, individual components can show variations caused by different production batches or model changes. This mainly affects the tolerances of the hinge holes, which can vary by a few millimeters (inches). A slightly different positioning of the hinges results in altered door movement and fit.
This is a very important point. The alignment of the side panels directly at the new location is crucial, as even minimal unevenness in the floor or wall cannot be compensated for and will cause the doors to no longer close flush.
If possible, I recommend checking the side panels of the shelf with a spirit level and a protractor and, if necessary, correcting with small shims. Afterwards, a careful adjustment of the hinges is advisable.
One last factor I want to mention is the change in ambient temperature and humidity during the move, which can cause the material to expand or contract. This means the components will no longer fit the shelf frame perfectly, affecting door function.
Please let us know if the new room has different climate conditions compared to the old storage room. That would help a lot in providing further advice.
Laukau5 schrieb:
...the shelf frames in the new location could also be slightly out of alignment or not 100% level...
