ᐅ Why do screws sometimes come loose in Billy shelves?
Created on: 15 May 2021 14:37
Paulo
Paulo
15 May 2021 14:37
Hello everyone, I have noticed several times that screws sometimes come loose from my IKEA Billy shelves, which is obviously annoying and affects the stability. My question is: why do screws sometimes come loose from Billy shelves? So far, I haven’t been able to identify a clear reason, whether it’s due to the assembly, the quality of the screws, or the material of the shelf itself. I am also interested if anyone has experience with how to solve this problem permanently without having to keep tightening the screws. Thanks in advance for your input!
dunitan
15 May 2021 15:12
Hello Paulo,
thank you for your detailed question. Generally, screws tend to come loose in Billy shelves mainly when the threaded holes in the wood material do not hold properly or when the assembly was not done precisely. Billy shelves are made from particleboard, which is not as uniform as solid wood, making the material more prone to losing its screw-holding strength.
Additionally, these shelves are often heavily loaded – heavy books or decorations can cause slight movement of the furniture over time, which can loosen the screws. It is important to tighten the screws neither too much nor too little, so the material is not damaged and the screws do not come loose quickly.
A common tip is to use some wood glue or a special threadlocker (e.g., Loctite) if the screws keep coming loose. This often helps to maintain stability over a longer period.
If you want, I can provide more detailed instructions on how to keep the shelves stable permanently.
PAUREO54
15 May 2021 15:45
Screws often come loose because the MDF or chipboard material tends to wear out over time. Simply tightening them usually helps. If that’s not enough, stuffing small pieces of wood into the hole and then re-screwing often works well.
LANICOLE
16 May 2021 09:22
Hello Paulo and all interested,
I would like to add a structured explanation and a small how-to guide to address the issue of loose screws in Billy bookcases as effectively as possible.
1. Cause: As dunitan already mentioned, particleboard materials like those used in Billy bookcases are porous and not as dimensionally stable over time as solid wood. The threaded screw holes can wear out or widen, especially when the shelf is loaded or moved.
2. Assembly tips: When assembling, screws should always be tightened evenly and never overtightened – this can damage the material. However, a screw that is too loose can gradually work its way out due to vibrations or weight.
3. Repair option: If you frequently have problems, loosen the screw, clean out the hole, and fill it with wood glue and small wooden dowels or toothpicks cut to size. Then you can reinsert the screw. This creates new grip in the porous material.
4. Alternatives: Another option is to use special furniture repair kits, such as multipurpose wood filler or threaded inserts, which stabilize the shelf.
PAUREO54 schrieb:
If that’s not enough, stuffing small wood pieces into the hole and rescrewing often works well.
Yes, this works particularly well when combined with wood glue, as it helps the material hold firmly together again.
I hope this helps you further. If you need detailed repair steps, feel free to ask again.
