Lately, I have been experiencing the problem that screws loosen over time despite seemingly proper installation and the correct applied torque. This happens both with machinery in operation and with statically mounted parts. My question is therefore: Why do screws come loose despite proper installation? By that, I mean that the screws were tightened correctly according to the specifications, with the appropriate torque, and, if necessary, with locking elements, yet they still eventually yield or come completely loose. What could be the causes of this, and what should be considered during installation or when selecting screws to prevent this?
The issue of screws loosening on their own despite proper installation can usually be attributed to several technical factors. One common cause is exposure to vibrations or dynamic forces, which can gradually reduce the clamping force within the thread. Even if the correct torque is applied, this is sometimes not enough to maintain the connection under continuous vibration.
It is important here to verify whether the securing elements are truly suitable for the specific application. For example, simple spring washers or plastic locking devices offer limited protection against vibration, while locking rings, adhesives, or self-locking nuts are often more effective.
Additionally, the surface condition of the threads and the type of lubricant used also play a role. Too much or too little lubrication can distort the actual torque applied, leading to insufficient clamping force.
In summary: vibrations, inappropriate locking methods, incorrect lubrication, and material compatibility are the most common causes.
Fibernd schrieb:
The screws were tightened properly according to the specifications, using the appropriate torque and securing elements
May I add something? The cause of screws loosening despite proper installation should always be investigated systematically. It is important to understand not only the assembly itself but also the entire load case and the installation conditions in detail.
First, regarding the assembly: the tightening torque is only an indicator of the preload – which is essential. If the screw head or the nut is loaded unevenly, it can cause indentation marks that reduce the preload.
Furthermore, vibration, especially with changes in direction, is critical. Such dynamic loads can loosen the screw connection if they are not supported by appropriate locking methods.
That hits the mark exactly! I would additionally point to chemical thread lockers (e.g., Loctite), which are particularly effective under dynamic loads. But the appropriate surface finish on the thread (such as zinc-plated, black oxide, or plain) and the correct lubricant choice are also crucial.
What are the environmental conditions where the screws loosen? Are there temperature fluctuations, corrosion, or other influences? Such factors can further affect the material and the joint.
I recommend a process-oriented analysis and, if needed, tensile or vibration testing of the connection to determine the actual preload after assembly.
CHENFAR schrieb:
Hier ist es wichtig zu prüfen, ob die Sicherungselemente auch wirklich für die jeweilige Anwendung geeignet sind
This topic has got me thinking as well, since during my own installation work I was often unsure whether the screws would actually stay tight. I really appreciate that so much expert knowledge has already been shared here!
That's exactly my situation too: sometimes you work in environments with significant temperature changes or even humidity. You often don’t think much about that, but it definitely affects the joint.
I also wonder a bit whether the subjective feeling of having “tightened properly” can be misleading at times. Sometimes you don’t have a proper torque wrench on hand or simply lack the experience, so you can’t really judge if the clamping force is correct.
I really like the tips about different locking methods. I will definitely pay more attention to those in the future and also try to focus on details like lubrication and thread type. Thanks for that!
bapar schrieb:
What kind of environment are the screws loosening in? Are there temperature fluctuations, corrosion, or other factors?
Oh, this topic is really interesting and important! 🙂
In my workshop projects, I’ve also experienced screws coming loose even though I thought everything was done perfectly – that’s really frustrating! But the posts here are very helpful. Especially the tip from CHENFAR about locking devices was great.
Exactly! I used to just use regular spring washers – and suddenly, everything would loosen up. Now I use special self-locking nuts, and that works much better!
The explanation about vibration also really clicked for me. Now I’m going to look into some adhesives or products with chemical locks. That sounds almost brilliant!
Thanks for the valuable tips, I’m motivated to make my screwed connections even more secure next time! :-)
CHENFAR schrieb:
It is important to check whether the locking devices are really suitable for the specific application.
