I have recently noticed that Malm screws tend to loosen relatively quickly, even when tightened with the specified torque. I am particularly interested in understanding why this phenomenon occurs so frequently.
I would like to know which physical or mechanical factors promote loosening, whether the material plays a role, how friction between the thread and the screw head affects this, and if there are design measures to minimize loosening.
Could mechanical play, vibrations, thermal stresses, or settlement behavior be responsible?
I look forward to your opinions and experiences on this topic, as well as any further insights or practical tips to prevent this issue.
A precise answer to the question "Why do Malm screws loosen so quickly?" requires knowledge of the specific application conditions.
The issue usually stems from a combination of settling behavior, friction loss, and dynamic vibrations. If the screw is considered as an elastomer with some damping characteristics, the forces acting on it are gradually reduced due to wear, causing the clamping force to decrease over time.
Furthermore, the thread design of Malm screws is often less optimized for maintaining preload, which promotes loosening.
The solution lies in technical improvements and the use of locking elements or special constructions with two nuts or locknuts to prevent loosening.
rilau4 schrieb:
Could mechanical play, vibrations, thermal stresses, or settling behavior be responsible?All of these factors indeed contribute to Malm screws loosening quickly.
Mechanical play causes micro-movements that gradually lead to loosening over time. Vibrations accelerate this effect significantly.
Thermal stresses also cause expansion and contraction in the material, which reduces the clamping force.
In general, when screws loosen quickly, it is always important to check whether the screws used have the appropriate strength classes and thread qualities.
Investing in higher-quality screws with locking features usually proves to be worthwhile.
KAMERON schrieb:
Exact tightening torque and the correct tightening procedure are crucial.I agree with that.
Additionally, a corrected tightening procedure (e.g., tighten, loosen, retighten) can reduce settling behavior.
This is especially important in critical applications where a secure bolted connection is essential.
