ᐅ Why do Malm nightstands wobble even after assembly?
Created on: 5 Jul 2015 08:33
ANNINA
ANNINA
5 Jul 2015 08:33
I am currently dealing with a problem that many IKEA furniture owners are probably familiar with: Why do Malm nightstands wobble despite being assembled correctly according to the instructions? The parts fit together well, all screws are tightened, and I have checked and adjusted the adjustable feet underneath. Still, there is a slight, noticeable wobble, especially when the table is used as a surface for placing items. I am interested in whether the issue lies in the design, material tolerances, or perhaps an unsuitable floor surface. Alternative ways to stabilize the furniture are also welcome. Who has had similar experiences and can share causes and solutions?
chenlen
5 Jul 2015 10:47
The wobbling of Malm nightstands despite proper assembly is often caused by a combination of factors: First, the materials used, such as particleboard, are prone to minor irregularities. Even if the assembly instructions are followed exactly, slight manufacturing tolerances in drilled holes or fasteners can lead to uneven distribution of weight. Additionally, the floor where the nightstand is placed is often uneven. Especially on irregular carpets or wooden floors without an underlay, it is not always possible to completely eliminate wobbling. An additional securing method, such as using angle brackets on the wall or rubber pads on the legs, can provide lasting stability.
tutan
5 Jul 2015 11:59
chenlen schrieb:
…a combination of several factors…
Yes, exactly! Malm is solid, but Ikea manufactures efficiently, and sometimes the tolerances get tight on thin plywood. 🙂
Often, just adjusting the leveling feet precisely is enough for me, but if the floor is uneven, you can’t get it perfectly stable. I’ve even glued small felt pads underneath, which helps. And please don’t overtighten the screws, or they will pull into the board and reduce stability.
Sure, it’s annoying when you assemble the cool table and it still wobbles. But in return, it’s lightweight, affordable, and looks great – not everything can be perfect.
bareynaldo
6 Jul 2015 09:05
I believe this discussion about the wobbling of the Malm nightstands lacks sufficient critical perspective. Why do we expect a piece of furniture made from particle board to have the same stability as solid wood? IKEA produces mass-market products for the average consumer, which inevitably involves compromises in durability and material strength.
ANNINA schrieb:
… whether the problem lies in the design, material tolerances, or the unsuitable surface underneath.
In my opinion, the main issue lies in the design and choice of materials. If you buy a nightstand at the price of a good dining table, don’t expect miracles. The wobbling is almost inevitable; it is the price you pay for being able to assemble it yourself. What’s worse is that many people try to fix it afterward with various tricks – often doing more harm than good.
Parmin
7 Jul 2015 19:22
Interesting discussion, I will take a more analytical approach here:
The wobbling of the Malm nightstands after proper assembly indicates that the stiffness of the joints is not sufficient to withstand lateral loads.
chenlen schrieb:
…minimal manufacturing tolerances in the drilling holes or connectors…
These tolerances cause micro-movements at the connection points, which become noticeable when placing items on the surface.
Furthermore, the construction is based on rather thin engineered wood panels, which are only connected at specific points with fittings. This results in the nightstand having basic stability under vertical pressure, but very little resistance to lateral forces.
bareynaldo schrieb:
Anyone buying a nightstand at the price of a good dining table should not expect miracles.
I agree with this.
One possible solution would be to install additional wall fasteners alongside the adjustable feet or retrofit a more rigid base frame to secure the unit against tipping. Only in this way can the wobbling be technically reduced without compromising the appearance.
