Some time ago, I bought a Malm nightstand from Ikea, but I noticed that it wobbles slightly even when placed on a flat surface. My question is: why do Malm nightstands tend to wobble, and what methods can be used to fix or at least reduce these stability issues? I suspect it could be due to manufacturing tolerances, uneven floors, or the design itself. I look forward to detailed answers, preferably with practical suggestions on how to quickly solve this problem in everyday use.
The wobbling of Malm bedside tables is a well-known issue and can usually be traced back to several causes. First, the manufacturing tolerances for Ikea furniture are generally fairly tight but not as precise as those of higher-end furniture. The back panels are often thin, which limits additional stability. Second, uneven floors play a significant role—even slight height differences of a few millimeters in laminate or hardwood flooring can cause the furniture to wobble. Third, the construction and assembly affect stability: if screws are not properly tightened or dowels are not correctly inserted, the stability decreases.
To fix this, I recommend the following:
- Check and tighten screws and connectors
- Place felt pads with leveling function or furniture wedges under the feet
- Optionally secure the back panel additionally with brackets
- For especially uneven floors, use small shims underneath or install height-adjustable furniture glides
These measures should stabilize the bedside table permanently.
Joshbe schrieb:
uneven floors The most important issue is usually the floor. I stabilized my nightstands using small rubber pads, which works very well. Otherwise, always check the screws.
To fully address the issue: Malm nightstands often wobble because their design—with a thin back panel and relatively large surface areas—is susceptible to minor unevenness. Additionally, these tables are typically made from particleboard, which can flex under pressure.
Besides the mentioned options, it is advisable not only to stabilize the table on uneven floors with shims or felt pads but also to carefully check the connections such as screws and fasteners. Another tip: the rear fixation against the wall is often insufficient—adding wall anchors or brackets can significantly improve stability.
For those who want to quickly eliminate wobbling without sourcing building materials, experimenting with furniture glides is recommended. Depending on the floor type, there are hard or soft versions that can compensate for slight unevenness. Also, after assembly, firmly tightening the screws noticeably increases stability.
It is important to consider the load when assessing stability. Excessive weight distribution on the nightstand reduces its steadiness—a more even distribution of weight has a positive effect.
