ᐅ Why Do Malm Furniture Pieces Shake?
Created on: 3 May 2023 10:17
Mekau49
Mekau49
3 May 2023 10:17
I have a somewhat more specific question that came up regarding my Malm furniture: Why do Malm pieces sometimes feel wobbly even though they appear stable and solid? Especially with the drawers, you can sometimes feel a slight sway or give, even when everything has been assembled correctly. Are there known weak points or common issues that cause this wobbling effect? I am particularly interested in whether this is related to the design, the materials, or normal wear and tear over time.
Perhaps someone here has experience with Malm furniture facing this issue or knows how to fix it permanently. Thanks in advance for any input!
jan10
3 May 2023 10:39
Malm furniture often wobbles because the connections on the drawer slides become loose. Simply tightening all the screws again usually helps.
nojaus
3 May 2023 11:05
I know this well; it bothered me quite a bit back then. For me, regularly checking the screws helped, but it’s frustrating when you’ve done all the work properly and still have this wobbling. Does anyone have experience with reinforcements that solve this problem long-term?
jeix9
3 May 2023 13:22
Most of the time, uneven floors cause the furniture to wobble. A simple shim placed under one corner can often fix the problem.
noge58
3 May 2023 13:55
Oh yes, the topic of wobbling with Malm furniture! 🙂 I had that problem too, and what helped me was simply removing all the drawers one by one and checking the fasteners! It’s amazing how small screws can affect such a large piece of furniture. Just be brave, everyone, you can handle this! 🙂
draFrederi
4 May 2023 08:17
noge58 schrieb:
It's amazing how small screws can have such an impact on a large piece of furniture.
That's true, I once wobbled an old dresser until I found the screws that were almost coming loose. After tightening them, it was sturdier than new – such a small detail with a big effect! Sometimes it's these unassuming little helpers that make all the difference. :-)
