ᐅ Why do Malm drawers stick even when everything is installed correctly?
Created on: 24 Jul 2020 09:17
DANIGU
I recently got an IKEA Malm desk with drawers and assembled the drawers according to the instructions. However, I am having issues with the drawers sticking or not opening and closing smoothly. I have properly aligned and screwed in the metal side rails and checked that nothing is bent. The drawers themselves are straight and were assembled precisely according to the plan.
My question is: Why do Malm drawers stick even when everything is assembled correctly? Are there any possible causes I might have overlooked that could lead to friction or jamming, even though everything appears to be as it should?
I look forward to your insights and tips on what else I can check or adjust to get the drawers working smoothly again.
kauti
25 Jul 2020 09:02
DANIGU schrieb:
Are there any possible causes I might not have considered that could lead to friction or jamming, even though everything formally appears to be as it should?
An important cause is the slight variation in geometry due to manufacturing tolerances in IKEA furniture. The particle boards can be slightly warped to different degrees, which leads to inaccuracies in how the drawers slide.
Additionally, it should be noted that Malm drawers use roller or ball-bearing slides whose axles can wear out slightly or become blocked over time—especially if dust or foreign particles have accumulated.
Also check whether any screws are sticking out too far and hitting the inside of the drawer wall, and whether the metal slides run exactly parallel (deviations under 1mm (0.04 inches) can be problematic).
If all mechanical components are exactly as specified, the minor warping of the board is often the issue. This can be fixed by gently bending or carefully sanding the affected edges.
GU-LAU60
26 Jul 2020 07:38
I recommend fully pulling out and pushing the drawers back in several times after installation to identify any sticking points.
Then adjust the guide at the identified spot or, if necessary, round off edges.
Often, the issue is caused by sharp edges or misaligned guides.
klo40
26 Jul 2020 08:22
FAZAR schrieb:
My tip: Completely disassemble the drawer and rails, check each component, and then reassemble them slowly step by step, testing the drawer’s movement along the way.
This is a very good approach.
I would like to add: Users often underestimate the importance of the drawer bottom panel resting properly on the side rails. If the bottom panel is warped due to screw pressure, it can cause jamming – so the panel should be checked for flatness before final assembly.
Also, make sure the front panel is not set too low, putting pressure on the runners.
Overall: Precision is key when working with Malm drawers. Careful assembly that takes small deviations into account prevents most problems.
