ᐅ Why do Malm drawers squeak when opened?
Created on: 31 Aug 2024 08:12
ELDEO66
ELDEO66
31 Aug 2024 08:12
Hello everyone, I have recently noticed that my Malm drawers make a squeaking noise when opened, which is quite annoying. I’m curious: why do Malm drawers squeak when opened? Is the issue related to the mechanics, the materials, or possibly how the drawers are used or maintained? I’m asking because I’ve read a bit about sliding metal runners and plastic components as potential causes, but I would like to look at this topic from several angles to find out if the squeaking can be permanently eliminated. Maybe some of you have personal experience or technical knowledge that could help. I’d appreciate it if you could share your thoughts!
Kinbu
31 Aug 2024 09:03
Hello ELDEO66, your question is very precise and addresses the core of many common furniture issues. Basically, Malm drawers usually squeak due to friction between the metal runners and the sliding rails, which are often made of plastic. If these components are not well lubricated or if dust and dirt accumulate, noise occurs while sliding.
Another possible cause could be that a plastic wheel or glide has slightly deformed, for example due to years of use or temperature fluctuations. In that case, the materials no longer fit perfectly together and squeaking can occur in certain spots.
A tip: Generally, it helps to thoroughly clean the runners and treat them with a suitable lubricant. Keep in mind: silicone oil or special furniture glides are better suited than WD-40, as the latter can leave residues and attract dust again.
Jensson
31 Aug 2024 10:27
To bring some structure to the topic, here is a brief overview of why Malm drawers may squeak when opened:
1. Mechanics: Malm drawers often use metal runners with plastic sliders or rollers. Over time, these can wear out or dry up.
2. Friction: Without sufficient lubrication, friction increases, especially if dust or small particles are present in the runner system, causing squeaking.
3. Installation: A drawer that is incorrectly installed or slightly warped may no longer slide smoothly.
4. Material expansion: Wood reacts to changes in humidity, which can cause slight misalignments within the system.
5. Lack of maintenance: Regular cleaning and lubrication are important to keep the sliding motion smooth.
My advice: First, thoroughly clean the runners, then treat them with a silicone-based lubricant. If rollers are damaged, they should be replaced.
When doing this, the drawer should be fully removed and the runners carefully inspected.
nubar
31 Aug 2024 11:45
The causes of squeaking in Malm drawers are mainly related to the metal and plastic components. A particularly effective long-term solution is the use of Teflon-based lubricants, which provide very low friction.
It is important to ensure that the rails are completely free of dust before applying the lubricant, as dust greatly reduces its effectiveness.
Additionally, you should check whether the drawer is sticking in the track or if foreign objects are blocking it. Sometimes, a slightly stiff spring mechanism in the slide can also cause the noise, which would require closer inspection.
There is no one-size-fits-all answer, but the combination of maintenance, cleaning, and the right lubricant usually leads to the best results.
sanjon
31 Aug 2024 12:52
Squeaking usually comes from dry metal rails or dirty plastic guides. Simply clean them and lubricate with silicone spray or a bit of petroleum jelly. This usually helps immediately.
Palenar
1 Sep 2024 08:15
Interesting question you raised, ELDEO66. The squeaking in Malm drawers is technically caused by microscopic friction vibrations that occur when two surfaces—usually metal against plastic or metal against metal in your case—slide past each other.
These friction vibrations mainly happen when the surfaces are uneven due to dirt, micro-deposits, or improper installation.
Very often, it is the plastic glide pads that slightly deform over time, affecting the height or alignment of the drawer. Small debris or dust trapped in the rails can also contribute to the squeaking by creating localized pressure points.
To address the issue thoroughly, I recommend the following steps:
1. Remove the drawer completely
2. Clean the drawer slides thoroughly, possibly using a solvent or mild cleaning agent
3. Let them dry
4. Apply a high-quality silicone spray sparingly
5. Reinsert the drawer
If the squeaking persists afterward, check the glide pads for cracks or wear and replace them if necessary.
One more note: The materials used in Ikea furniture are often not designed for long-term use in more humid living spaces. High humidity or temperature fluctuations can worsen the behavior of the materials. Have you noticed such conditions in your environment?
