Some time ago, I bought a Malm bed from IKEA, which I generally like, but unfortunately, it often squeaks. The annoying, persistent noise is especially noticeable when turning over or sitting down.
I’m curious why Malm beds – which are marketed as relatively sturdy – squeak so frequently. Is it due to the design, the materials used, or perhaps the way the parts are assembled? Are there known weak points in these beds that cause this issue?
I would appreciate any expert opinions or tips on preventing or fixing the squeaking, as it becomes really disturbing and bothers me at night over time.
Thanks in advance!
Thanks in advance!
The squeaking usually comes from the joints. Screws and brackets tend to loosen easily, causing movement—and therefore noise. Simply tighten all screws thoroughly once again. If it still squeaks after that, apply some lubricant to the joints using graphite or silicone spray.
sonpar schrieb:
The squeaking usually comes from the joints.That is correct. MALM beds are made from MDF boards and particle boards, which, combined with metal brackets and screws, are relatively prone to movement under pressure.
The most common causes of squeaking are:
1. Loose screws and connections
2. Moisture exposure causing slight swelling of MDF and particle boards
3. Missing or insufficient lubrication at the contact points between wood and metal
The construction is stable, but due to the interaction of different materials, noises like this can occur under load and movement.
Regular maintenance, meaning tightening screws regularly and occasionally applying a suitable lubricant, significantly reduces the problem.
Lalatau schrieb:
Loose Screws and Connections – absolutely, that’s what I would guess as well.You could almost say the bed has developed a bit of "play" because everything shifts and creaks. Kind of like an old door that sticks.
Besides tightening, I recommend using small felt or rubber pads at the contact points. This reduces friction and usually makes the squeaking much quieter or stops it altogether.
Also, if you’re handy, take a look at the slatted bed base: if it’s not properly seated or wobbles, that also adds to the creaking noise.
So: tighten the screws, use some lubricant, add small cushions in between – then it will get quieter in the bedroom. 🙂
Elodie schrieb:
small felt or rubber pads on the contact surfaces +1That’s really a great tip! I had exactly the same problem with my MALM bed and used simple felt pads from the hardware store, placing them between the slatted frame and the bed frame. Result: absolute silence.
By the way: a little WD-40 (of course applied carefully, not directly on the wood) also helps to quiet moving metal parts. But I’m always a bit cautious with it, in case it’s too harsh for the material.
Better a little too little than too much.
A bit of DIY like this often makes the bed feel much more comfortable. 🙂
