ᐅ Why Do IKEA Brimnes Drawers Squeak and How Can I Fix It?
Created on: 15 Aug 2020 08:23
pifeyaz
pifeyaz
15 Aug 2020 08:23
I have a problem with my IKEA Brimnes drawers – they squeak quite loudly when opening and closing, which is very annoying. I suspect it has something to do with the drawer slides or the materials used, but I don’t have a clear idea what exactly causes it. Has anyone had experience with why Brimnes drawers often squeak? And most importantly: what practical solutions or repair methods can be used to permanently eliminate the noise? I’m grateful for any tips, whether about lubricants or possible adjustments!
Kinbu
15 Aug 2020 09:47
Hello pifeyaz,
regarding your issue with the squeaking IKEA Brimnes drawers: The squeaking often occurs due to friction on the drawer slides or the plastic rollers inside the drawer. Especially in dry environments or after prolonged use, the lubricant film can wear off, causing metal or plastic parts to rub against each other without enough lubrication.
A first step would be:
- Completely remove the drawers.
- Check if the rollers or slides are damaged or dirty.
- Then treat the metal parts with a silicone-based lubricant, as it neither attracts dust nor damages the materials.
- Important: Do not use oily substances, as they attract dirt and only worsen the problem.
If the issue is defective plastic rollers, replacing them is recommended. IKEA sells spare parts for Brimnes.
This way, you can usually solve the problem quite easily and effectively. If you like, I can also provide more detailed instructions on disassembly and lubrication.
PAR63
15 Aug 2020 12:36
To add to Kinbu’s input, here is a structured guide to fix the squeaking issue with IKEA Brimnes drawers:
1. Fully pull out the drawer and, if possible, remove it completely from the furniture unit.
2. Visually inspect the sliders and rollers for any damage.
3. If any plastic rollers are damaged, replace them (there are suitable replacement rollers available).
4. Remove any old lubricant residues with a lint-free cloth.
5. Then spray the metal parts, such as the drawer slides, with a silicone-based dry lubricant or treat them with a dry-film grease.
6. Move the slides gently to distribute the lubricant evenly.
7. Reinstall the drawer and open and close it several times to test.
Important: WD-40 or oil on metal parts is usually counterproductive because it attracts dust. Also, some oils can damage plastic components. A silicone spray specifically designed for use on both plastic and metal is a much better all-round solution.
If you have firmly screwed the drawers in place, also check that all screws are tight, as loose parts often cause noise as well.
marmar50
15 Aug 2020 15:02
In short: Drawers usually squeak because the plastic rollers or metal tracks are dry. Simply remove them, clean, apply silicone spray, and you're done.
Kolepau
16 Aug 2020 07:45
marmar50 schrieb:
Drawers usually squeak because the plastic wheels or metal tracks are dry.
That was exactly my experience! Then I sprayed silicone lubricant, and just like that – the problem disappeared completely! 😊
I can only encourage you to give it a try; it makes a huge difference. I was surprised myself at how simple it was. And hey, who doesn’t know it – squeaky furniture is just so annoying! So keep at it, and if the wheels get overloaded or worn out, you can simply order replacements from IKEA and swap them out. It’s wonderful how small tricks like these can make our everyday lives easier 😄!
