ᐅ Why do the connectors come loose with Billy?
Created on: 22 Nov 2022 18:07
Furumo
Hello everyone, I have recently noticed an unusual problem with my Billy shelf: the connectors seem to come loose on their own, without me directly causing it. More specifically, it is often the pins or dowels that are supposed to hold the shelves in place. My question is: why do the connectors on Billy shelves come loose?
The joints are not subjected to excessive load or installed incorrectly, at least I think so. I have considered material fatigue or assembly weaknesses, but maybe there are other reasons I have overlooked. Perhaps temperature fluctuations, humidity, or even design flaws could be the cause?
I look forward to your insights and tips, as I would like to keep the shelf stable. What have your experiences been with these connectors on Billy shelves?
Rhett
23 Nov 2022 08:19
Loose connectors in Billy often occur due to vibrations or uneven flooring. Make sure the shelf is stable and tighten the screws. In cases of high humidity, consider using sealants.
O
ODINFLO
23 Nov 2022 09:02
Guyju schrieb:
Avoid overtightening the screws, as this can cause the material to split or weaken the joint.
Very good advice! This is often underestimated. Additionally, cheaper chipboard materials, like those used in Billy, are generally more susceptible to overstrain.
However, I would also like to point out that manufacturer quality should occasionally be questioned. Are there any reports of batch problems or quality differences with Ikea? Does anyone have sources?
I’m interested in whether the system is fundamentally a weak point or if these are isolated cases.
naujon
23 Nov 2022 09:45
Regarding material and quality evaluation, I have conducted some research:
Billy is mainly made from MDF and particleboard materials, which are inexpensive but fairly sturdy for everyday use. However, they do not offer the same durability as solid wood.
In fact, there are no official reports about general quality defects with IKEA products; issues are more often related to assembly difficulties and environmental factors.
My advice: When assembling, try to use the original connectors and focus on careful workmanship. If you plan to disassemble and reassemble frequently, you might also consider alternative fasteners that are more robust, such as metal brackets or additional screws.
This way, you can improve stability even if the original design reaches its limits.
