ᐅ Why do the colors of Billy bookcases change?
Created on: 13 Aug 2017 19:32
gustafma
gustafma
13 Aug 2017 19:32
I recently purchased several Billy bookcases from IKEA and noticed upon closer inspection that the colors vary slightly depending on storage location, lighting conditions, or even between different production batches.
My question is: Why do the colors of Billy bookcases change? Are there common reasons such as material differences, aging of the finish, or environmental factors like UV light or humidity that can cause discoloration or variations in tone?
It would be very helpful if someone knows the causes or can share experiences with color changes in Billy bookcases. I am especially interested in which factors are truly responsible and whether it is possible to avoid such color differences.
Garry
13 Aug 2017 20:11
Color changes in Billy shelves are usually due to several factors. One is the variation between different production batches: IKEA regularly reproduces them, and small differences can occur in the paint or the melamine foil material used.
Another significant factor is UV light. The white or cream-colored laminate can fade or develop a yellowish tint when exposed to direct sunlight. Similar effects can occur from high humidity or temperature fluctuations, which can alter the material over time.
gustafma schrieb:
Are there common reasons such as material differences, aging processes of the finish, or environmental influences like UV light or humidity?
Based on my experience and manufacturer information, these points are particularly relevant. If you make an effort to protect your shelves from direct sunlight and maintain a consistent ambient temperature, you can reduce color variations.
Noahlu
14 Aug 2017 08:47
There are some technical details to consider when explaining color changes. IKEA typically uses a combination of melamine-coated particle boards and painted edges for Billy shelves. These surfaces react differently to external factors.
1. Production variations: Particle boards can have slightly different shades across different batches, as wood-based materials are naturally not completely uniform. The applied melamine foil also shows some color variation.
2. UV exposure: Melamine foil yellows over time due to exposure to UV light. The paint on the edges can expand or slightly discolor under high temperatures and humidity.
3. Chemical exposure & cleaning: Using inappropriate cleaning agents can damage the paint layer and cause color changes.
In your case, I would be interested to know in which rooms and under what lighting conditions the shelves are placed, as this greatly influences the changes.
gustafma schrieb:
Gibt es typische Gründe wie Materialunterschiede, Alterungsprozesse des Lacks oder Einflüsse durch Umwelteinflüsse
In conclusion: material composition and environmental factors are the main causes. A tip to avoid this: buy identical shelves from the same production batch whenever possible.
farkin
15 Aug 2017 12:05
I would like to structure my response to better explain the causes of color changes in Billy shelves:
1. Production and Material-Related Differences:
- Particleboards made from wood-based materials naturally have color variations.
- Melamine coatings and paints are applied industrially in large batches, so minor differences in color and gloss are unavoidable.
2. Aging Processes:
- UV exposure especially causes white or light colors to yellow or fade.
- Heat and moisture can alter coatings and films over time.
3. Environmental Influences:
- Direct sunlight accelerates fading.
- Humidity and temperature fluctuations promote uneven material expansion.
- Cleaning with aggressive agents can damage surfaces and cause color differences.
4. Handling and Storage:
- Uneven storage or transport conditions can cause minor damage or color changes even before assembly.
In summary, I recommend purchasing new shelves as close together in time as possible and avoiding exposure to direct sunlight. Also, use a mild, pH-neutral cleaner for maintenance.
Garry schrieb:
If you make sure to protect your shelves from direct sunlight
Exactly, this is often the most important advice.
Noahlu schrieb:
A tip to avoid issues: buy identical shelves from the same batch whenever possible
I can confirm this – especially if you want the appearance to match across multiple shelves.
If you have any further questions, I am happy to help.
