ᐅ Why do BILLY shelves still wobble despite being attached to the wall?
Created on: 10 Jun 2021 18:23
eljaluHello everyone, I recently purchased several BILLY shelves from IKEA and, as recommended, secured them to the wall using the included wall fasteners. Despite proper installation and use of the anchors, the shelves still noticeably wobble, at least when lightly bumped or when something leans against them. My question is: why do BILLY shelves wobble even when attached to the wall?
I made sure the screws are properly tightened, the wall fasteners are screwed in at the correct height and preferably into a load-bearing spot. The shelves also stand flat on the floor, so there is no risk of tipping from below. Could the wobbling be due to the shelf construction itself, the type of attachment, the wall material, or are there other common causes to consider?
I look forward to your insights and tips, as I would like to avoid any wobbling – safety is the priority.
eljalu schrieb:
Why do BILLY shelves wobble even when fixed to the wall?Hi eljalu, I’m familiar with this issue – BILLY shelves aren’t exactly the most solid, but if installed correctly, they should be fairly stable. Often, the problem is that although the wall fixings are installed, they either use too few screws or the screws aren’t fully embedded in the anchors. Also, if the wall is made of drywall, for example, the grip is usually not very strong.
My advice: Use metal anchors or special anchors designed for your wall type and make sure to screw the brackets in tightly. If it still wobbles, try adding small brackets underneath the shelf, securing them to the shelf board – this provides much better support and prevents tipping.
Don’t worry, with a few tricks you can make your BILLY shelves really stable :-) Good luck!
Hello eljalu, I am happy to provide a structured explanation of the causes and solutions for wobbling despite wall mounting.
1. Wall condition: For BILLY shelves, anchors are usually used. In solid walls (concrete, brick), everything holds firmly, while drywall or other soft materials generally offer less stability.
2. Mounting location of fasteners: Fasteners should be placed as close as possible to the top edge of the cabinet. If they are installed too low, the leverage effect of the tall shelf can increase the tipping moment.
3. Number and quality of screws or anchors: One or two anchors may be insufficient for a shelf weighing about 7 kg (15 lbs) under load. It is recommended to use at least two fasteners, preferably three.
4. Shelf base and feet: Uneven flooring often causes wobbling. Check with a spirit level whether the shelf is standing level, and if necessary, compensate using felt pads or washers.
5. Shelf cabinet: Due to the flexible material and lightweight wood, some slight movement can still occur despite wall mounting.
Summary: Wobbling despite wall mounting is often caused by a combination of wall material, fastening method, location, and shelf construction. Retrofitting with additional brackets or a sturdy base is almost always recommended.
kaju67 schrieb:
If it still wobbles, try attaching small brackets underneath the shelf That’s a great tip! I had also been wondering for a while why my shelf suddenly felt unstable. It made me quite uneasy because you start to question whether it’s really secure or if it might eventually topple over. The small brackets really gave me peace of mind.
Also, if you can’t eliminate the wobbling completely right away, it’s okay to get used to a bit of movement at first, as long as the fixings remain secure. Just make sure the screws don’t become loose from the motion.
Especially when children or pets are in the house, safety is of course a top priority. That’s why I think this topic is very important and I’m glad you brought it up.
