ᐅ Why do BILLY brackets come loose under heavy load?
Created on: 21 Nov 2024 08:23
Eilertbi
Eilertbi
21 Nov 2024 08:23
I am facing an issue where the brackets of my IKEA BILLY bookcases come loose under heavy load. This mainly concerns the wall fixings, which are supposed to provide stability.
I assembled the shelves according to the instructions, using all the dowels and screws provided, but over time the brackets seem to loosen or even pull out of the wall, which obviously greatly affects safety and load capacity.
My question is: Why do BILLY brackets come loose under heavy load? Are there design weaknesses, common installation mistakes, or is the furniture simply not designed for certain loads?
I am especially interested in how forces are distributed on the screws and wall fixings, and whether the material quality or installation materials could play a role.
I look forward to your assessments and expert opinions!
lisku
21 Nov 2024 08:47
The BILLY brackets are often designed for moderate loads.
If they come loose, it is often due to:
1. Incorrect anchors or a wall that is too soft.
2. Improper tightening of the screws.
3. Overloading beyond the weight limit.
I would first check the anchors used and, if necessary, switch to heavy-duty anchors.
Filippo
21 Nov 2024 10:05
Hello Eilertbi,
First of all, thank you for the detailed description of your problem – it provides us with a good foundation.
To answer your question comprehensively: The BILLY shelves are solid, but the load on the brackets – especially at the wall – creates leverage forces that are often underestimated. These leverage forces act on the wall brackets in such a way that the screws are subjected not only to tensile forces but also to bending moments.
lisku schrieb:
Overloading due to weight.
This hits a crucial point. The shelves are basically designed to safely carry a certain maximum load, but if the center of gravity within the shelf contents shifts (e.g., heavy books placed at the front), increased leverage forces occur, putting additional strain on the screws.
The quality of the mounting material is also important. For example, if it is drywall without suitable anchors, the holding power of the screws is often insufficient.
lisku schrieb:
Wrong anchors or wall too soft.
Therefore, it makes sense to use special hollow wall anchors or metal anchors for drywall. Likewise, heavily perforated or aged walls can worsen the problem.
What is the condition of your wall? Did you use standard anchors or special heavy-duty anchors? The source of the problem often lies in the combination of furniture weight, mounting materials, and wall substrate.
Another tip: The BILLY brackets must be securely fastened to the wall, but when tightening the screws, be careful not to overtighten, as this could cause the anchor to slip inside the drill hole.
It would also be interesting to know if the shelf itself has been modified in terms of material or connections (stability reinforcements).
Filippo
koduga
22 Nov 2024 11:17
Thank you for the detailed response, Filippo. I can understand how frustrating it must be when you put effort into the installation and the shelf still becomes unstable.
Filippo schrieb:
The BILLY shelves are solid, but the load on the brackets—especially on the wall—creates lever forces that are often underestimated.
That matches my own experience. You think you did everything correctly, and suddenly the anchor doesn’t hold as firmly or the screw feels loose.
Often it helps to distribute the load well and maybe avoid fully loading just one shelf board, instead placing heavier items lower down or even near the floor.
One issue I often see is that, especially in rental apartments, the walls aren’t always designed to support heavy loads for extended periods. When small cracks or minor damage appear, the brackets lose even more grip.
What has always helped me is getting a feel for the resistance of the anchors during installation and, if necessary, choosing alternative fasteners for particularly heavy shelves.
I hope this helps a little, Eilertbi! Keep at it; sometimes it’s just trial and error finding the right combination of shelf contents, wall, and fasteners.
