ᐅ Why is it no longer possible to repair Malm furniture the way it used to be?
Created on: 22 Feb 2020 09:13
Paolo60
Lately, I have been thinking a lot about repairing furniture, especially the popular Malm furniture from IKEA. In the past, wooden furniture could still be repaired or restored quite well on your own: tightening screws, using glue, or selectively replacing parts – this often worked easily and lasted a long time. Today, however, I often fail even at the attempt to bring a Malm shelf or dresser back to a stable condition.
So my specific question is: Why is it no longer possible to repair modern Malm furniture in the same way as traditional wooden furniture used to be repaired? What technical or design-related reasons make repairs much more difficult or even impossible?
I would appreciate detailed explanations, preferably with references to the materials or construction techniques used that prevent this.
Tommy38
23 Feb 2020 09:15
Luciandi schrieb:
I would prefer an option where you can at least get individual replacement parts,
That is a request I can fully understand. Unfortunately, IKEA has designed the system so that complete parts are usually sold only as whole units, and individual components are rarely available. This mainly applies to connectors and side panels.
However, there are small suppliers who offer repair kits for particleboard and common fasteners. These kits typically include repair dowels, glue, and so-called "doubling plates" – which can often reinforce brittle areas.
One more tip: when assembling, handle the connections carefully. It’s best to initially tighten all screws only by hand and only fully tighten them at the end. This way, the material suffers less.
Paolo60
23 Feb 2020 10:03
Tommy38 schrieb:
One more tip: If you handle the connections carefully during assembly, it’s worth tightening all screws only by hand at first and only fully tightening them at the end. This way, the material is less likely to suffer damage.
Thanks for the tip! That’s exactly what has happened to me several times: In the heat of the moment, you tighten the screws too quickly and the material starts to crack.
Do you have any experience with adhesive solutions? I once tried using PU wood glue on Malm furniture, and while the glue held the board together, the edge veneer partially peeled off or formed bubbles. Does anyone know of alternatives or special adhesives for plastic laminates on particleboard?
danial60
23 Feb 2020 10:38
Paolo60 schrieb:
Does anyone use PU wood glue on plastic coatings?
This is challenging because PU wood glue adheres best to porous, absorbent surfaces. For foil coatings, like those commonly used on Malm furniture, the glue sticks less effectively and moisture can lift the decorative layer.
An alternative would be two-component epoxy adhesive. These adhesives are stronger, harder, and also bond well to smooth surfaces. However, you need to apply the adhesive very sparingly and precisely, as epoxy is harder and more brittle than wood glue and can break if applied incorrectly.
Another option is specialized construction adhesives for plastic and wood, often referred to as hybrid or MS polymer adhesives. These provide some flexibility and can help when bonding particleboard with foil. When repairing, it’s important to minimize stress on the glued or broken area.
My advice: do small tests in inconspicuous spots before applying glue over a large area.
meGreg
24 Feb 2020 08:22
I once repaired a Malm bed where a plastic joint broke. I simply used epoxy resin – it was a bit of delicate work, but it held up well. You just have to be careful to apply it to the right spot and secure it properly from the start.
If you want, you can also see it as an upcycling project – giving a disposable product a bit more useful life. It’s kind of satisfying when it works. 🙂
Maybe IKEA should offer “repair kits” with color-matched veneers and adhesive. I’m sure many customers would appreciate that.
