Hello everyone, I have recently noticed that my Billy bookcases especially make a very unpleasant squeaking noise when opening the doors. I usually associate this with furniture that has poorly lubricated hinges, but in the case of the Billy bookcases, the noise seems unusually loud and annoying.
My question to you is: Why do some Billy bookcases make a “noisy” sound when opened? In other words, why do some models or units produce this loud, squeaking noise? Is it due to the assembly, the materials, or could it be a common issue with certain batches? Are there proven methods to reduce or eliminate the noise without having to disassemble or significantly modify the furniture?
I look forward to well-informed answers and perhaps some experiences on how to technically explain or easily avoid this problem. Thank you!
Basically, the 'noisy' sound when opening BILLY shelves mainly comes from friction in the hinges and the plastic or metal connectors that attach the door panel to the carcass.
This point is correct, as the absence of lubricant on the hinges leads to noise. However, it is also important to consider that the material pairing, especially with MDF wood-based panels, can easily swell under unfavorable humidity conditions, increasing the stress on the fittings.
Furthermore, installation accuracy plays a role. If the doors are not perfectly aligned, this creates additional mechanical strain and thus noise.
The best measures against squeaking are – as mentioned – applying appropriate lubricants, adjusting the hinges with an Allen key for optimal alignment, and if necessary, making slight readjustments to the fittings.
Paunon schrieb:
The squeaking usually comes from unlubricated or poorly fitted hinges.
I mean, almost everyone knows this, right? A squeaky BILLY shelf is almost a little everyday furniture challenge 😉
The problem often comes down to the combination of inexpensive materials and the mechanical stress from opening and closing. A little “lubrication” for the hinges can work wonders – just a few drops of oil and suddenly everything runs more smoothly 🙂
I’ve also noticed that new BILLY shelves can sometimes be a bit louder at first, until the mechanism “settles in” a bit. So don’t worry, it usually improves over time!
I can definitely understand the frustration when a cabinet door makes loud noises when opening; it’s really annoying in everyday life.
Have you checked if the hinges are properly tightened? Even with lubrication, loose screws can cause noise. Sometimes it also helps to slightly loosen the hinges, realign them, and then tighten them again.
That’s really an important point—I experienced the same. It might be worth taking a close look with a spirit level and Allen key before considering lubricants. 🙂 If you have any questions about the best adjustment, feel free to ask!
bupar schrieb:
Assembly precision plays a role. If the doors are not aligned exactly, this creates mechanical stress and therefore noises.
This issue may seem trivial at first, but honestly, it has annoyed me as well—especially since BILLY shelves are generally associated with easy handling. I personally noticed that the noises tend to get worse on doors that are used frequently.
To me, this suggests it might also be related to wear and tear. Perhaps the movements become less smooth over time, causing the squeaking.
I would recommend that too, but also regularly check if everything is still firmly in place. Especially with frequent use, screws can gradually become loose.
@dodirk: How often do you use the doors approximately? Have you tried any lubricants yet, or have you been cautious about making changes so far?
meGreg schrieb:
a bit of ‘lubricant’ on the hinges can work wonders here
