I have noticed that some IKEA Billy bookcases seem less stable than others, even though they look identical at first glance and have the same model name. I am curious why this might be the case. Could different materials or production batches be used, such as varying qualities of wood panels or different joining techniques? It would also be interesting to know whether assembly differences or how the shelves are loaded play a role. Has anyone had experience or explanations that could help clarify why some Billy bookcases appear more stable than others?
I find this topic interesting because people often expect the same product to provide the same stability. However, IKEA manufactures worldwide – and even with standards in place, quality control can vary between different factories.
I agree, and on top of that, some people simply buy the wrong model for their load requirements or underestimate how important wall mounting actually is. There’s a mix of expectations and the actual product reality. If you’re not careful, you end up with a wobbly shelf.
Joshbe schrieb:
The screws and wall plugs used often vary.
Layla schrieb:
Maybe some people underestimate the importance of this special wall mounting with BILLY?That sounds plausible. My question would be how much the variations between different batches actually affect the stability? Essentially, the shelf is intended for books, so standard heavy loads. For example, whether deviations in the particleboard thickness or manufacturing inaccuracies are typical or just exceptions.
Vinson schrieb:
How much do the variations between individual batches specifically affect stability?This cannot be specified generally, but based on my research, variations within a single production run are usually minor. It becomes problematic when substitute materials are used due to supply chain optimization or material shortages.
Particle boards could then be slightly thinner or less densely compressed. In practice, this means a reduced load-bearing capacity, which is often only noticeable under full load. Incorrect assembly, on the other hand, is immediately apparent. Therefore, with unstable shelves, I always recommend first checking the quality of the assembly.
Vinson schrieb:
Are deviations in the thickness of particle boards or processing inaccuracies typical, or are they just exceptions?Good question! Small defective batches can happen, usually caused by dusty storage or product returns. IKEA typically replaces such shelves without issue.
I also recommend, especially for tall shelves carrying heavy loads, to add angle irons or metal brackets under the shelves yourself and to securely fasten the back panel – this helps a lot.
Finally, I want to say: If the shelf wobbles, it’s not the end of the world. Just double-check that all parts are properly seated and secure – and assemble it with a bit of care. 😉
Sometimes it’s a matter of luck, but most of the time you can stabilize a shelf unit like that quite well.
