I have a question that has been on my mind for a while and I’m hoping to get some clear explanations here: Why can some Billy shelf boards be difficult to remove?
I’ve noticed that in my Billy bookcase, some shelves get stuck or only come out with significant force, while others can be removed easily. I’m using standard shelf boards, not any special or custom versions.
I’m wondering if the issue could be related to the design, material expansion, the support strips, or manufacturing tolerances. I’m also curious if differences in production years or load conditions might make it harder to take the shelves out.
Does anyone have experience, technical insights, or tips on how to safely release stuck shelf boards without damaging the bookcase or the shelves?
I’d appreciate any well-informed answers!
Levinu schrieb:
Why are some Billy bookshelf shelves difficult to remove?A very good and precise question, which I am happy to answer in detail:
Various factors can cause individual shelves in Billy bookcases to be hard to remove. First, it is important to know that the shelves are made of particleboard, which can easily expand when exposed to moisture. This expansion causes the shelves to get stuck in the grooves or on the support pegs.
A second point concerns the small plastic or metal shelf supports on which the shelves rest. If these do not fit exactly or shift out of place, the shelf can become misaligned.
Furthermore, the assembly condition of the bookcase plays a role: A slightly unevenly installed bookcase or warping can cause increased pressure on certain shelves, making removal more difficult.
My tip would be to gently tap the shelf with a rubber or wooden mallet before removal and carefully insert a thin plastic putty knife or similar tool between the shelf and the side panel to prevent misalignment.
Summary:
1. Wood or panel expansion due to moisture
2. Inaccurate or shifted support pegs
3. Assembly and installation condition
Manufacturing defects or stresses over the years can worsen the problem.
Nabla64 schrieb:
The shelves are made of particleboard, which can easily expand when exposed to moisture.That is certainly an important factor, but in my opinion, it doesn’t tell the whole story. There are also shelves that withstand the same humidity levels, yet the shelves still become hard to move.
I would therefore add that manufacturing tolerances play a bigger role. If the shelf board has been produced even slightly too wide or too thick, removing it becomes difficult.
KINMIN4 schrieb:
Sometimes the shelves fit too tightly due to manufacturing tolerances.I agree with that, but it’s also important to check whether the groove in the side panel might be slightly warped. This can be observed with some variations of Billy shelves.
Additionally, you shouldn’t overlook that in older shelves, the glue at the edges might swell. This changes the fit of the shelf.
Overall, I believe it’s a combination of several precise causes, with production accuracy and moisture effects being the key factors.
