ᐅ Why are some BILLY doors harder to close?
Created on: 21 Oct 2022 18:37
jugadu
jugadu
21 Oct 2022 18:37
I have had BILLY shelves from IKEA for a while, and I have noticed that some BILLY doors close much more difficultly than others. I am interested in understanding the exact reasons for this.
Are these differences mainly due to design variations, material defects, or do the hinges and their installation play a role?
Or could factors like humidity or the adjustment of the shelving unit itself cause the doors to stick repeatedly? Is there a way to realign the doors so they close more easily without gaps?
I would appreciate a detailed explanation or tips for resolving this issue.
barEsperan
21 Oct 2022 19:02
jugadu schrieb:
I am interested in what exactly causes this.
This is usually due to poorly adjusted hinges. They can be easily readjusted with a screwdriver.
Wood can also expand or contract, especially in high humidity, which can cause the door to appear warped.
tra_nina
21 Oct 2022 20:14
The difficulty in closing BILLY doors has several causes. First, most IKEA BILLY doors are equipped with adjustable metal hinges.
Imprecise adjustment can cause the door to not fit perfectly within the frame, leading to issues when closing. Additionally, the wood fibers are sensitive to changes in humidity, which can cause the doors to warp slightly.
The load distribution also plays a role: if the shelf is heavily or unevenly loaded, the doors often press at an angle, making it harder to close them properly.
It is recommended to regularly check and, if necessary, adjust the hinges according to the IKEA instructions to ensure optimal closing functionality.
RETRAVIS
22 Oct 2022 08:46
tra_nina schrieb:
An improper adjustment causes the door not to fit precisely within the frame
Correct. Additionally, it can be noted that the hinges themselves may sometimes show wear or minor damage, which affects smooth opening and closing.
Furthermore, the attachment of the hinges to the cabinet or frame can become loose, making alignment more difficult.
Finally, the installation location is also crucial: In rooms with high humidity or temperature fluctuations, the material expands or contracts more, which should be taken into account when adjusting.
jan10
22 Oct 2022 11:23
RETRAVIS schrieb:
The material expands more under high humidity
Exactly. That’s why door hinges should be regularly checked and adjusted if necessary.
Jamming usually occurs due to moisture or incorrect installation.
