ᐅ Why are MALM furniture pieces often so fragile or delicate during assembly?
Created on: 5 Mar 2021 14:17
U
uskeo
U
uskeo
5 Mar 2021 14:17
When assembling my Malm furniture, especially the dressers, I have often found them to be quite delicate. Specifically, I mean that screws tend to get damaged easily, or the particleboard at the joints swells or tears out.
My question is: Why are Malm furniture pieces often so fragile during assembly? Is it due to the design, the materials, or possibly the assembly instructions?
I would appreciate it if anyone with experience or background knowledge could share their insights and maybe explain which factors are involved and whether this can be avoided or improved. Thanks in advance for your input!
theo63
5 Mar 2021 15:03
uskeo schrieb:
Why are MALM furniture pieces often so fragile during assembly? Is it due to the design, the materials, or maybe the assembly instructions?
Good question. From what I can tell, the fragility of MALM furniture mostly comes down to the materials used: IKEA often uses particleboard with a lacquer or foil finish for these items, which unfortunately isn’t very durable.
This means mechanical stress, especially at connection points with screws or dowels, can quickly leave marks or cause damage. Particleboard is not solid wood and tends to swell or break down under excessive load.
I’ve also often read that the assembly instructions tend to be quite basic and don’t always provide the necessary tips on how to reinforce certain joints.
However, I’m a bit skeptical that this alone explains all the damage: sometimes the issue is also due to rushed handling, wrong tools, or simply a lack of care during assembly.
Maybe it’s helpful to distinguish two factors here: the objective sensitivity of the materials and the subjective errors during assembly—do you notice any signs of assembly mistakes, or does it seem different from your perspective?
Naomige
5 Mar 2021 16:45
theo63 schrieb:
Particleboard is simply not solid wood and tends to swell or break down under excessive load.
That sums it up well. I would like to add that MALM furniture is primarily designed for budget-conscious customers. This explains the choice of materials like coated particleboard instead of more expensive woods.
Particleboard is cost-effective and allows for industrial mass production with consistent quality. However, it naturally has limitations in terms of strength and durability, especially in damp environments or with rough handling.
IKEA’s assembly instructions are usually aimed at average users, designed to be easy to understand, and feature clear, illustrated step-by-step guides, which is generally very good. However, they often lack warnings about special precautions that would be advisable with this material—for example, carefully screwing in fasteners to prevent the particleboard from fraying or the holes from widening.
Another point is that some joint mechanisms, such as cam lock fasteners or dowels, are not quite as durable in particleboard as in solid wood. The only solutions here are careful workmanship and sometimes additional reinforcements if long-term stability is desired.
Liduta
6 Mar 2021 09:22
Naomige schrieb:
Assembly instructions from IKEA [...] often lack warnings about special precautions
I agree with this and would like to share some tips for assembling that many people overlook with MALM furniture, which can lead to fragility:
1. Do not fully drive all screws into the material: Especially with particleboard, screws should only be driven in until resistance is felt, without forcing them further. Otherwise, the edge can break out.
2. Pre-drill when making additional adjustments: If you need to add holes for extra screws or anchors, pre-drilling helps prevent the material from breaking apart.
3. Follow the correct order: During assembly, many parts need to be lightly secured simultaneously before tightening all screws fully—if you tighten one spot too early and firmly, other parts may become misaligned.
4. Use screwdrivers with torque limiters: This helps avoid over-tightening, which can cause swelling or breakage.
5. Be careful with storage before and during assembly: Particleboard is sensitive to moisture and extreme temperatures, so it should be stored as dry as possible and at room temperature shortly after purchase.
By paying attention to these points, the assembly will not only be less fragile but the furniture will also last longer.
fikeo
6 Mar 2021 11:36
uskeo schrieb:
Why are MALM furniture pieces often so fragile during assembly and construction?
I can confirm this from my own experience with MALM dressers as well.
In my opinion, the main reason lies in the choice of material (particleboard) and the manufacturing process. The boards are relatively thin to keep the furniture lightweight and easy to transport – but this also results in disadvantages regarding stability.
Furthermore, the assembly instructions can seem a bit sparse for inexperienced DIYers. If you apply too much force with the tools or assemble parts slightly misaligned, the material can be easily damaged.
What always helps me personally is patience during assembly. I have made it a habit to do a dry fit of all steps first – meaning carefully putting all parts together before fully tightening the screws.
I also recommend using cordless screwdrivers with torque control. This protects the material better than sharp manual screwing or overtightening.
Have others here tried similar approaches successfully?
Ramon4
7 Mar 2021 08:50
theo63 schrieb:
... potential error source during assembly
An additional note from my perspective: Many people underestimate how important proper handling of fittings and tools is when working with particle board furniture.
Often, the included screws are somewhat stiff, or the pre-drilled holes can fray slightly if you over-tighten the screws. This can cause small cracks that may expand over time or result in the screws no longer holding securely.
I would also recommend lightly treating the screws with wax or soap before driving them in – this makes the process smoother and better protects the material.
And if you’ve ever assembled one of these pieces and damaged the edge coating, you should definitely consider using adhesive edge bands as a repair measure.
In conclusion: The sensitivity lies, in my opinion, in the combination of particle board material, often fairly thin parts, and sometimes less than perfect assembly instructions.
However, those who work carefully and with the right technique can significantly reduce these problems.
