ᐅ Why are Malm dressers often wobbly?
Created on: 22 Aug 2017 08:37
Anfloria44
I am currently looking into a phenomenon with IKEA Malm dressers and hope to find some expert insights here. Although these dressers are affordable and feature a simple, elegant design, many users report that they are quite wobbly – which can lead to safety and stability issues.
My question is: Why are Malm dressers often unstable, even though they appear sturdy at first glance? Is it due to the construction, choice of materials, or possibly the assembly process? Could factors such as the load or the type of floor also play a role? I would appreciate detailed explanations, including tips on how to potentially fix the issue or suggestions for alternative options.
HORST41
22 Aug 2017 11:56
I can understand the concerns about wobbling—especially when there are small children at home.
Peone schrieb:
Furniture should ideally be placed on solid, level surfaces.
For me personally, adding extra angle brackets and corner reinforcements to my Malm dresser helped a lot. It noticeably improved the stability. I also regularly checked and tightened the screws.
I also think IKEA should take this issue more seriously because, for the price, I don’t expect such instability. However, the low price is of course a compromise that you have to consider.
Katau
23 Aug 2017 07:48
A few practical tips again:
First, always place the chest of drawers on a perfectly level surface. It’s best to check the horizontality with a spirit level.
Second, it’s worth lightly sanding the original drill holes of some connection points with fine sandpaper to ensure the screws fit precisely and without tension.
Third, metal brackets on the inside corners of the chest provide reinforcement – this reduces the play in the wood and significantly increases stability.
And not to be underestimated: securing the furniture to the wall, as IKEA explicitly recommends, greatly improves stability and prevents dangerous tipping.
BLAKEO
23 Aug 2017 09:53
I would like to add one more thought:
No piece of furniture is more stable than the construction and materials used allow.
Katau schrieb:
The wall mounting, which IKEA explicitly recommends, greatly increases stability
That makes sense and also complies with safety standards that have been mandatory for furniture to reduce accident risks for several years now. However, IKEA could adapt the design so that stability is ensured even without wall mounting, or at least make it much easier to implement.
There is also a trend toward flatter armrests and larger openings in furniture, which comes at the expense of structural strength. A new design concept would be needed here if both stability and aesthetics are to be achieved equally.
cassandra
23 Aug 2017 10:27
One last point:
Tolerances in mass production are another factor. If the panels are not cut precisely or the drill holes are slightly misaligned, it can affect the final fit of the joints and thus the overall stability.
Therefore, careful assembly and, if necessary, additional work on the wood (sanding edges, tightening screws) are often required to achieve the best result.
It is also advisable not to overload the dresser, especially the upper drawers, so that the load is distributed optimally.
chenValeri
24 Aug 2017 08:03
Wobbling usually results from uneven floors and loose connections. Tightening screws, using felt pads or adjustable feet, and reinforcing the back panel usually helps.
Tobias
24 Aug 2017 08:11
Reinforce the back panel and always secure the dresser to the wall. The quality of the particle board cannot be changed, but proper installation can compensate for it.
