ᐅ Who uses wooden drawer inserts instead of plastic ones in the KALLAX?
Created on: 12 Apr 2024 18:07
kenpraHello everyone,
I am currently looking into equipping my KALLAX shelving unit with drawer inserts. I place great importance on using sustainable materials and am wondering: Who actually uses wooden drawer inserts instead of the typical plastic versions for the KALLAX system?
I am especially interested in how the wooden options perform in terms of craftsmanship, durability, and everyday usability. It would also be interesting to know if users prefer specific types of wood and whether the ecological benefits justify any potential extra cost. Practical tips on cleaning and maintaining these wooden drawers would be helpful as well—after all, plastic is probably easier to care for.
In short, I’m looking for experience and recommendations from members here who can provide insight specifically on wooden drawer inserts for KALLAX. Thanks in advance for your thoughts!
kenpra schrieb:
Who actually uses wooden drawer inserts instead of the classic plastic versions for the KALLAX system?For my KALLAX, I actually chose wooden drawers, even though they are somewhat heavier. The look is simply unbeatable—much warmer and more premium than the cold plastic.
When it comes to maintenance, I occasionally apply a light coat of oil to the wood surfaces. This keeps them moisture-resistant and enhances their natural shine.
Another advantage I’ve noticed is the durability. The wooden drawers feel sturdier and last longer with frequent use.
Of course, everyone makes their own choice, but I really like the natural appearance and can definitely recommend it. 🙂
kenpra schrieb:
How different types of wood perform in terms of workmanship quality, durability, and everyday usabilityTo go into a bit more detail: wooden drawers for the KALLAX shelf are usually made from plywood or solid wood, which distinguishes them from common plastic drawers.
Because of the wood construction, the load capacity tends to be higher – however, the exact quality depends heavily on the manufacturer. Cheap plywood can warp or swell quickly when exposed to moisture, which can affect the drawer’s function.
The drawers are attached inside the KALLAX compartments using wooden slats, which requires a certain level of precision when inserting them. It’s worth paying attention to product recommendations with good fit and tolerance.
For everyday usability, I also recommend considering the surface finish: sealed layers or oiled finishes are more resistant to stains and scratches over time compared to untreated wood.
Finally, a question for you: Are your priorities mainly functional, or do appearance and tactile feel also play an important role? That could help in recommending the right type of wood or finish.
juMira46 schrieb:
The look is simply unbeatableI completely agree. Wooden drawers are obviously heavier, but more durable. Maintenance is easy: just clean occasionally with a dry cloth and treat with wood oil if needed.
kulau schrieb:
It’s worth paying attention to product recommendations with good fitThat’s my main point. Some wooden drawers are either too big or too small and then wobble in the KALLAX. Avoid no-name products; it’s better to invest a bit more.
