ᐅ Who uses reinforced bases for additional weight support with the KALLAX?
Created on: 27 Jul 2021 08:23
rheamarHello everyone,
I am currently planning to reinforce my IKEA KALLAX shelving unit to safely hold heavy items. During my research, I came across the topic of "reinforced bases for increased weight capacity on the KALLAX."
I am particularly interested in hearing from those of you who use such reinforced bases and about your experiences. For example: What type of base do you use (metal, wood, other materials)? Approximately how much additional weight can it support?
I am also curious whether the stability and firmness really improve noticeably and if there are any special tips for installation.
In short: Who uses reinforced bases to increase the weight capacity of their KALLAX, and how has it worked out for you in practice?
Looking forward to your replies!
Hey rheamar!
It’s great that you’re taking on this project! :-) I’ve been using a metal base for my KALLAX shelf for several months now and can only say: highly recommended!
I built a steel frame that fits like a kind of “plinth” under the shelf. It can easily support twice the weight compared to the original IKEA feet. Nothing tips over anymore, and the whole thing feels very stable.
Installation was straightforward—you only need a few tools and maybe a helper for assembly.
I’d say: just give it a try. For the money invested, you get a lot of safety and support! 🙂
Interesting approach, Kolepau.
However, before simply stating that a metal substructure is always better, it’s important to consider whether the weight and load distribution have been properly calculated.
That sounds promising, but what loads and distribution were tested? A general statement is difficult without reliable data.
Furthermore, it’s not just about the weight, but—as rheamar also asks—the stability and how the substructure affects the overall shelving unit. There could be risks if it is assembled incorrectly or if the point load is too high.
Does anyone have reliable experience or measurement data on this?
Kolepau schrieb:
It easily supports twice the weight compared to the original IKEA feet.
I find the discussion interesting, but honestly:
Is a KALLAX really designed to carry very heavy loads?
I'm surprised no one has pointed out that this should usually be solved differently. Use the KALLAX as a light shelving solution, and for very heavy loads, opt for a different, more robust structure.
Anyone who modifies their furniture this way risks more than they realize. But I’m open to being convinced otherwise – looking forward to real-life examples!
rheamar schrieb:
Who uses reinforced bases for carrying more weight with the KALLAX, and how has that worked out for you in practice?
I implemented a simple solution at my place, and it works great and is really fun! :-)
A sturdy base made from plywood and some metal brackets supports my KALLAX perfectly, allowing me to store heavy items like stacks of books and toolboxes safely.
It was important to me to customize the base so that it fits exactly under the shelf and distributes the load evenly. This keeps everything stable and also looks neat.
Just ask at the hardware store which types of wood are strong and relatively affordable – then get to work with a strong screwdriver! 🙂
From my own experience, I can say that it makes a big difference whether you are just storing a few boxes or actually overloading the shelving unit.
Some time ago, I reinforced a KALLAX shelf with a strengthened base frame, partly to ensure greater safety. Adding extra crossbars and sturdy metal legs gave me a lot of peace of mind.
What I have learned is that you shouldn’t focus solely on the base supports, but also make sure that the individual shelves can hold more weight. So consider a complete renovation if you plan to store many or heavy items.
A small tip at the end: regularly check that everything is still securely in place—especially when moving heavy loads.
