ᐅ Who uses painted back panels to add a splash of color to their Kallax shelving unit?
Created on: 15 Aug 2022 19:23
nedim
nedim
15 Aug 2022 19:23
I am considering painting the back panels of my Kallax shelf in a bright color to create a targeted color accent. My question to the community: Who uses painted back panels for color accents in the Kallax, and what experiences have you had with this? It would be helpful to hear details about color selection, the type of paint application (e.g., spray paint, rolling, brushing), as well as practical tips for surface preparation and application. I am also interested in whether the effort is truly worthwhile in terms of durability and appearance, or if there are alternative methods that achieve similarly good results. Thanks in advance for your feedback!
kulau
15 Aug 2022 20:02
Hello Nedim,
I have been using painted backing panels for the Kallax units for several years now. The main advantage for me is the high level of customization – the color accents create a much more vibrant piece of furniture compared to the usual wood tones.
For painting, I definitely recommend using high-quality spray paint, preferably applied in several thin layers, as it provides very even coverage and leaves fewer brush marks. Before painting, be sure to sand the backing panels carefully (grit 180 to 220) to improve paint adhesion. After sanding, thoroughly remove all dust particles.
One issue can be that the standard Kallax backing panels are thin and may warp easily – in this case, it helps to clamp them before painting or to replace them with a stable, thin multiplex plywood panel.
Durability is definitely achievable with good paint, but direct sunlight and moisture should be avoided. Alternatively, I recently tried vinyl films – they look good but are less durable and appear less high-quality.
I’m also curious: What colors are you considering, and why do you prefer painting over using vinyl films or similar options?
U
usbla
15 Aug 2022 20:47
Regarding painted back panels for Kallax, I can add the following:
From a technical perspective, either a two-component acrylic paint or spray paint is suitable for wood-based panels. A good primer is important because MDF or hardboard panels often do not absorb the paint properly without it.
The surface must be dust-free, grease-free, and dry. Applying the paint is easier at temperatures between 18 and 25°C (64 to 77°F) to achieve an even finish.
A clear coat is also recommended to increase scratch resistance.
Strong contrasts are especially popular color choices, such as dark blue, mustard yellow, or daylight red.
It might be easier to decide if you consider your planned room design. Painted back panels can, for example, nicely break up white or wood tones.
roryvin
15 Aug 2022 21:33
Six months ago, I upgraded my Kallax with painted back panels. I used a matte finish acrylic paint in metallic gray. Preparation was crucial: sanding everything, dust removal, and then applying several thin coats of paint with sanding in between.
The effort is definitely worth it, as the back panels add depth and a personalized touch to the furniture without losing its overall character. Plus, unlike wallpapers or adhesive films, the paint holds up better against moisture and wear.
One downside can be the extra effort required if you want to change colors later. Painted back panels are semi-permanent. However, especially when renovating a room, I find paint more flexible and cleaner to work with than wallpapering or applying adhesive films.
karlau
15 Aug 2022 22:11
kulau schrieb:
One issue can be that the standard Kallax back panels are thin and may warp easily – it helps to tension them beforehand or replace them with a stable thin plywood panel.
I think that's exaggerated! The back panels are simply cardboard, not designer furniture wood. Personally, I believe that if someone is willing to put in that much effort, they would be better off investing in a high-quality shelving unit.
Regarding color: colored back panels themselves are nothing new and, in about 90% of posts here, just a trend that gets boring quickly. It’s better to choose fascinating patterns or natural materials – they add more character than paint.
So before painting, it’s worth considering sticking with the minimalist original design.
liskar
16 Aug 2022 07:39
For clarity for everyone interested:
Painted back panels in Kallax shelving units have mainly two advantages:
1. Color accents create structure and visually separate individual compartments,
2. the surface is easy to clean and more durable than simple fiberboard panels.
However, the type of paint used is important. A thin, high-quality paint layer has advantages over veneers or films (no peeling, better stability).
For DIY projects, I recommend water-based acrylic paint – low odor, fast drying, and more environmentally friendly. Solvent-based paints are more durable but less pleasant to work with.
My recommendation: if you don’t paint regularly, it’s better to use spray paint for a more even finish.
