ᐅ Who uses Kallax as a shelving unit for electronic devices?
Created on: 13 May 2022 09:37
Ivo_ken38I
Ivo_ken3813 May 2022 09:37Hello everyone,
I am considering using an IKEA Kallax shelving unit as storage for my various electronic devices. Specifically, I mean using the shelf for devices like routers, amplifiers, small gaming consoles, charging stations, and possibly smaller audio components. My question to the community is: who uses Kallax as a shelf for electronic devices, and what are your experiences regarding ventilation, cable management, and durability?
I am especially interested in practical tips for organization, how you might have modified or supplemented the shelf to ensure the devices function optimally (for example, heat dissipation, accessibility of connections, protection from dust), and whether the Kallax is generally a recommended solution for such purposes.
Thanks in advance for your answers!
That’s great that you’re considering using Kallax for electronic devices! 🙂 I’ve been using my Kallax for similar equipment for a while now and I’m really happy with it. It’s important to remove or cut out the back panel to allow air circulation. This significantly reduces heat buildup!
I installed LED strips on the inside and used cable clips – this keeps everything tidy and makes it easy to find the connections. I also routed small ventilation holes into the back panel. Another tip: don’t overfill the compartments, so there’s enough space for air to circulate. Good luck! 🙂
Ivo_ken38 schrieb:
I’m especially interested in practical tips for organizing, like how you might have modified or enhanced the shelf
I find the discussion interesting but would like to point out that the Kallax shelf, in its original state, has clear limitations when used as an electronics shelf. While its modularity is an advantage, you need to carefully consider heat dissipation.
This is exactly what I see as problematic: without the back panel, you lose stability and protection against dust. The shelf is not specifically designed for technical equipment. I would rather recommend using dedicated electronics cabinets with built-in ventilation if you want to store equipment for the long term.
Regarding cable management: the open back space helps, but it doesn’t look very tidy if you have many cables. There are some DIY solutions, but they can be quite elaborate.
ryan1 schrieb:
that you remove or cut out the back panel to allow air circulation
I can summarize the pros and cons well here:
The Kallax shelf unit is an affordable and flexible solution for housing small to medium-sized electronic devices. However, it is important to adapt it accordingly. For example, the back panels can be removed or perforated to improve air circulation.
That is true; an alternative is to attach a thin wooden or metal board behind the shelf, which is breathable or at least has some openings to keep dust out while still providing stability.
Also: cable management is actually crucial. Cable holders or clips help avoid clutter and prevent damage. I would also recommend not filling the space completely, as this can cause heat buildup, which reduces the lifespan of the devices.
If you need more information on implementation, I’m happy to provide examples. 🙂
Josefane schrieb:
Without a back panel, you lose stability and protection against dust
