ᐅ Who uses an acrylic panel as a top surface on the KALLAX?
Created on: 17 Apr 2024 08:37
Riaru
Riaru
17 Apr 2024 08:37
Hello everyone, I am planning to use an acrylic top panel for my IKEA KALLAX and would like to ask you: Who here uses acrylic sheets as a top for the KALLAX shelving unit? I’m especially interested in your experiences with the fit, stability, and practicality for everyday use. How well does the acrylic sheet attach or rest on the unit, does it fit the exact dimensions of the KALLAX, and what is your assessment of its scratch resistance and ease of cleaning? What purposes do you use this combination for, such as a desk, side table, or simply as a protective surface? A detailed evaluation would be great, as I am currently comparing different material options. Thanks in advance for your feedback!
Wesley
17 Apr 2024 09:52
Riaru schrieb:
Who here uses acrylic sheets as a top surface for the KALLAX shelf? I’m especially interested in your experiences with fit, stability, and everyday usability.
Hey, I have a clean acrylic sheet resting on my KALLAX—it really looks great! The fit was quite precise; you just need to make sure the sheet is custom-sized. I placed small silicone pads underneath to prevent slipping and protect the surface.
Regarding scratch resistance: acrylic isn’t extremely hard, but it holds up well under everyday use, and minor scratches can be easily polished out. Cleaning is very simple—just use a microfiber cloth with some mild dish soap.
I use it as a small desk extension and for decoration. It looks modern and is sturdy enough if you handle it carefully.
Paunon
17 Apr 2024 12:16
Wesley schrieb:
The fit was quite precise; you just have to make sure the panel is truly custom-made.
I agree. Don’t go for the cheapest option, or it won’t fit properly. I simply place acrylic sheets loosely, which is fine for light use. To avoid scratches, use a soft underlay or feet.
TEOZAR
18 Apr 2024 07:05
Hello Riaru,
I can relate well to your question about acrylic sheets on KALLAX. Regarding the fit: acrylic sheets are often available in standard sizes, but for a KALLAX shelf, I recommend having them custom cut by a workshop or a specialized retailer. This ensures a perfect fit.
As for stability: acrylic is sturdy but not as pressure-resistant as glass. For light to moderate loads, such as a surface for storage or a desk, it works very well. It’s important not to choose a sheet that is too thin—at least 4–6 mm (0.16–0.24 inches) thickness is advisable.
Regarding cleaning: acrylic is sensitive to harsh cleaners. It’s best to use a mild soap solution and soft cloths to avoid scratches. Also, consider that direct sunlight may cause the acrylic to discolor over time.
I use such a sheet on my KALLAX myself, mainly as a surface for plants and decorations—the surface stays easy to maintain and always looks elegant. Hope this helps!
Paxton38
19 Apr 2024 15:44
TEOZAR schrieb:
Regarding fit: Acrylic sheets are often available in standard cuts, but for a KALLAX shelf I recommend a workshop or specialist retailer that offers custom cutting.
That is correct. For precise fitting, there are providers offering cutting services online or locally. Pay attention to color and material properties, as acrylic sheets vary in hardness, UV resistance, and surface texture.
Riaru schrieb:
How well can the acrylic sheet be fastened or placed on top, does it fit exactly to the dimensions of the KALLAX, and what is your assessment of scratch resistance and cleaning?
A fixed screwing is not common because acrylic is sensitive to stress and can crack. It is more usual to simply lay it on top, often with anti-slip pads to prevent slipping. Scratches are generally an issue with acrylic; surface protection is advisable—for example, special films or lighting that does not cause glare.
I use a 5 mm (0.2 inch) acrylic sheet as a cover, as an addition to the KALLAX for decoration and light installation. With some care during use, the material holds up well.
