ᐅ Does anyone know any tips or tricks for assembling the Ikea BRIMNES furniture on your own?
Created on: 10 Aug 2018 08:37
sopra
sopra
10 Aug 2018 08:37
Hello everyone, I’m currently facing the task of assembling my new Ikea Brimnes chest of drawers and noticed while going through the instructions that it is a bit more challenging than I expected. I’m wondering if any of you have tried-and-true tips or tricks that make the assembly easier and help avoid mistakes. In particular, I’m interested in advice on the best way to sort the parts or the order in which to assemble them to save frustration and time. Maybe there are also recommendations on the use of certain tools or common pitfalls to watch out for in advance. So, who among you has experience with self-assembling the Ikea BRIMNES and can offer useful hints?
Le-so
10 Aug 2018 09:03
First, sort all screws and wooden parts by material and size. Then always work from the bottom up, making sure that all connections are secure before moving on to the next step.
marix
10 Aug 2018 09:38
The BRIMNES furniture is actually very well designed, but it can be a bit overwhelming at first. I would recommend carefully reading every step and not rushing anything. Often, people underestimate the importance of thoroughly checking the wooden parts before assembly – to ensure there are no defects or damages. For sorting, it helps a lot to spread everything out on the floor and group the pieces by type. A little tip: to secure the screws, a Phillips screwdriver with a good grip is better than a power drill, as it gives you more control and prevents overtightening, which could damage the material. If you get stuck, just take a moment to breathe and then calmly review the relevant section of the instructions again – sometimes small marks on the sides also help to keep track of where you are.
tutan
10 Aug 2018 10:05
marix schrieb:
It really helps to lay everything out on the floor and group the parts by type when sorting.
That’s invaluable! When I assembled the BRIMNES last time, I spread the parts out on an old blanket – the small pieces don’t slide away, and you quickly find what you’re looking for. And: Don’t rush yourself; enjoying the process of screwing things together makes a big difference 😉.
Le-so
10 Aug 2018 10:22
One more tip: Make sure to measure the boards where you will insert the dowels carefully. If the holes are not precise, it can cause wobbling. Tapping the dowels in properly, without forcing them, ensures a stable hold.
lumar58
11 Aug 2018 07:48
The instructions from Ikea are well designed, but the pictures can sometimes be confusing. With the BRIMNES, I found that it helps to fully assemble all the drawers first and only then work on the main frame. This way, you keep a clear overview and avoid additional installation errors.
