ᐅ Does anyone have tips for cleaning old KALLAX surfaces?
Created on: 9 May 2021 19:23
Jakero
Jakero
9 May 2021 19:23
I am specifically looking for good and proven tips on cleaning the surfaces of an older IKEA KALLAX shelf. The surface of my furniture is a bit worn and has small stains or dirt spots that I would like to remove effectively without damaging the material or the lacquer finish. It is the plain white laminate, not the glass or wood variants.
It is important to me that the cleaning method is gentle and does not leave any stains or roughen the shelf. It would also be helpful if you could share your experiences with home remedies or common cleaning products that are particularly effective and which ones should be avoided.
Thanks in advance for your recommendations and advice!
LENNAU
9 May 2021 20:41
Hello Jakero,
I completely understand that gentle cleaning is important to you. To start, I recommend gently wiping dirty KALLAX surfaces with a lightly dampened microfiber cloth to remove dust and surface dirt. Please avoid using harsh scouring agents or abrasive sponges, as these can scratch the laminate.
For tougher stains, try a solution of warm water and a drop of dish soap. Gently wipe the surface with this. If the stain remains, a mild all-purpose cleaner can be used, but be sure to apply it sparingly and test it first on an inconspicuous area.
Please avoid bleach-based or solvent-containing cleaners – these can damage and fade the white laminate surface. Finally, using a soft cotton cloth to polish the area will ensure a clean, streak-free finish.
I hope this helps you. If you have any further questions, feel free to ask!
Domau0
10 May 2021 07:36
Hello Jakero,
Your concern about the optimal cleaning of older KALLAX surfaces is technically well-founded, as laminate coatings can be damaged by inappropriate cleaning agents.
This is a very important recommendation.
I would like to add a detailed procedure:
1. Dust removal: First wipe the surface with a dry, soft cloth or microfiber cloth. This prevents scratches caused by adhering dust.
2. Prepare a mild cleaning solution: 1 liter of warm water + 1-2 drops of pH-neutral dish soap or a special laminate cleaner.
3. Cleaning: Gently clean with a well-wrung sponge or cloth in circular motions, without scrubbing hard.
4. Stubborn stains: For grease or adhesive residues, isopropyl alcohol on a soft cloth can help, but use sparingly and avoid large areas.
5. Rinse: Wipe thoroughly with clean water to remove any residues.
6. Drying: Immediately wipe dry with a dry cloth to prevent water spots.
In general, never spray cleaning agents directly onto the surface; always apply them first to the cloth to avoid over-wetting.
Jakero schrieb:
a cleaning method ... without spots or roughening
You achieve this best with patience and gentle treatment.
One more question: Does your shelving unit have deep scratches or discoloration from UV exposure? In that case, care products or special laminate polish might be an option if you want to mask minor damages.
Cecilera66
10 May 2021 09:14
Jakero schrieb:
Cleaning method is gentle and does not leave any stains
Be careful with vinegar or citric acid. They can damage laminate flooring.
Simply clean with warm water and a small amount of dish soap; do not mop wet, but use a damp cloth.
Don't forget to dry.
