ᐅ Who has tips for assembling an IKEA Metod tall cabinet accurately?
Created on: 28 Sep 2023 08:13
Z
zarvincenz
Z
zarvincenz
28 Sep 2023 08:13
I am currently planning to assemble an IKEA Metod tall cabinet and am looking for advice on how to proceed as precisely as possible, without needing significant adjustments afterwards.
My main question is: What specific methods or small tricks would you recommend to align the tall cabinet exactly and ensure that the doors and drawers close perfectly later on?
I am interested both in how to work with the assembly instructions (which, as we know, don’t always cover every detail) and how to handle uneven floors or walls.
For example, are there any tools you particularly recommend, or practical tips for pre-drilling, adjusting, or fitting?
I have already learned the basic technical terms, but I want to gather concrete and actionable tips to avoid mistakes and make the assembly as neat as possible.
Thanks in advance for your support!
Katan
28 Sep 2023 09:47
Good morning!
A quick tip before you start: stay calm during assembly, as Metod can sometimes be a bit tricky. 😉
From my experience, it’s best to take your time at first to unpack and sort all the parts and screws completely. This way, you avoid any surprises later on, like missing or incorrect pieces.
For uneven floors, I use small wooden wedges or special furniture levelers from the hardware store – this keeps the cabinet stable and prevents it from tipping over.
When adjusting the doors, a magnetic hinge adjuster often helps me. It’s easy to tighten or reposition without having to take the whole cabinet apart.
And don’t forget: when assembling, it’s worth using both hands and taking your time instead of rushing – everything fits together much better that way.
nonpra
28 Sep 2023 10:56
The most important thing first: use a spirit level for every step.
Pre-drilling does no harm, especially when attaching something to a wall.
Screw in the screws by hand at first and only tighten them fully at the end.
Nabla64
28 Sep 2023 12:04
Here is a brief step-by-step guide on how I proceed:
- First, sort and check everything (parts and fittings).
- Check the floor with a spirit level and, if necessary, level it using shims.
- Screw the cabinet together only enough to allow for adjustments later.
- Install and adjust doors and drawers only as the final step.
Important: If the floor is uneven, never press the cabinet firmly against the wall. This creates stress that can cause misalignments later.
Summary: Inspection, careful handling, adjustment at the end.
Z
zarvincenz
28 Sep 2023 13:29
Nabla64 schrieb:
Only screw the cabinet enough to allow for adjustments later.
That’s a very helpful point, thank you!
How much play do you usually leave when screwing it in? Do you suggest tightening all screws just enough by hand until the final assembly is complete, or are there screws you tighten more firmly because they serve a load-bearing function?
Also, are there any common pitfalls to watch out for when adjusting the doors that aren’t mentioned in the assembly instructions?
Blavin
28 Sep 2023 14:41
Regarding screwing: It is recommended to initially tighten the connection and mounting screws only by hand, so the cabinet can still be adjusted if necessary. Only after completing the alignment should all screws be tightened firmly according to the specifications.
Common pitfalls with Metod tall cabinets:
- Uneven pressure on the back panel: It must not be installed curved, as this can lead to warping.
- Incorrect alignment of the door hinges before installation: Hinges should always be checked and slightly pre-adjusted before attaching the doors.
- Ignoring wall or floor unevenness can cause stress.
For adjusting the doors, flathead screwdrivers and/or Torx bits for the hinges are recommended, as they allow precise adjustments.
