ᐅ Who has experience with alternative door fittings for Kallax units?
Created on: 16 May 2021 08:37
Glagrant
Glagrant
16 May 2021 08:37
Hello everyone, I bought a Kallax shelf unit and would like to change the usual look of the open compartments by adding door hinges. However, I’m not very satisfied with the standard hinge options commonly offered for Kallax. Therefore, I’m looking for alternative door hinges or mounting methods that are flexible, sturdy, and visually appealing. Has anyone already had experience with alternative door hinges for Kallax? I’m especially interested in systems that are easy to install, don’t require major modifications to the shelf, and are still durable. Maybe even DIY solutions or creative ideas?
I look forward to your tips and experiences!
Alberto51
16 May 2021 09:22
Glagrant schrieb:
Has anyone here already had experience with alternative door hinges for Kallax?
I can understand well how frustrating it can be when the standard solutions don’t meet your needs. It was similar for me, as I wanted to do some DIY with minimal effort but still achieve a solid result. A friend of mine suggested using magnetic catches combined with hinges from a hardware store, since these are often sturdier than the original folding hinge systems from Ikea. However, at first, I was concerned that this might make the unit unstable.
After several attempts, I concluded that a combination of strong magnets and flat hinges works quite well, especially if the unit is not rearranged completely every day. You just need to make sure that the door frame fits precisely, as this prevents alignment issues later on. If you like, I can provide more detailed instructions on how I installed it.
noge58
16 May 2021 10:18
I tried out a really cool solution!!! 🙂
I equipped my Kallax unit with sliding doors, but instead of the usual wooden tracks, I used small rollers from an old cabinet that I recycled! This is super practical because the doors slide very smoothly, and you don’t constantly bump into them while loading and unloading. It also looks really stylish. If you like a sleek appearance, you should definitely give this a try. It takes a bit of fiddling to fit the rollers properly, but the result is totally worth it!!
I’m really happy with it ;-)
Laurence
16 May 2021 11:05
noge58 schrieb:
I equipped my Kallax with sliding doors
Sliding doors are indeed an elegant solution that I can also recommend. However, with the Kallax, it’s important to keep in mind that the shelf itself is not necessarily designed to handle load on the sides, as can be the case with sliding door tracks. Therefore, I suggest testing the sliding door hardware on a separate board before installation to ensure they run parallel and don’t get stuck.
Regarding alternative door mountings, I can add that so-called “concealed hinges” (also known as “cup hinges”) are often used for Kallax doors because they are invisible and have good load capacity. However, if you prefer to avoid major modifications to the shelf, I would recommend clamp or magnetic fittings instead, since they are reversible and don’t damage the shelf.
How exactly will your door be opened? Is the space in front of the shelf limited, or do you have enough room for a door to swing open?
Glagrant
16 May 2021 13:46
Laurence schrieb:
How exactly is your door supposed to open?
Good question! The space in front of the shelving unit is indeed somewhat limited. So I’m looking for a solution where the doors open smoothly without requiring much force and without causing too much obstruction when open. That’s why I was also considering sliding doors, although I still lack detailed experience with those.
That sounds interesting, especially the idea with magnets. How exactly did you attach the magnets, and what type of hinges did you choose? And how did you ensure the door stays stable and doesn’t wobble? I’d appreciate a bit more detail so I can better assess whether this would work for my situation.
Surela
17 May 2021 07:48
I would like to take the discussion a bit further because the choice of door hinges for the Kallax is crucial for both stability and user experience.
First, it is important to know that the Kallax does not have pre-drilled holes for typical furniture doors like cabinets do. Standard cup hinges therefore require a frame or a mounting plate that can either be attached by drilling in or fixed on the back. This means the shelf itself is stressed on the sides, which can cause twisting in simple shelving units.
A very clever and stable solution is to use so-called “inset clips” combined with thin doors made from lightweight materials such as MDF or plywood. This minimizes the load. Alternatively, self-adhesive hinges with rubber backing are an option; these are less durable but suitable for lightweight doors.
Regarding sliding doors: you should opt for mid-quality track systems, ideally with ball bearings, which allow quiet and smooth movement. Installation needs to be precise here, otherwise misalignment and premature wear can occur.
Could you specify whether your doors will be made from heavier materials or if you prefer to work with as thin and lightweight doors as possible? That would help me provide more targeted advice.
