ᐅ Has anyone ever retrofitted a plug-in system into a Kallax shelving unit?
Created on: 31 May 2023 18:23
Batonio
I am currently planning to retrofit my IKEA Kallax shelf with a modular system to make the layout more flexible. Has anyone had experience installing such a modular system themselves in a Kallax after purchase? I’m especially interested in the practical challenges during installation, the materials required, and whether it’s really worth it in the end—particularly compared to ready-made solutions.
I would appreciate any advice on potential pitfalls or tips regarding stability and design. Thanks in advance!
sarGabriel
31 May 2023 21:09
It is very important: never make the drill holes in Kallax too large, as the material is thin. It is best to use 6mm (1/4 inch) dowels, no larger. Otherwise, nothing will hold.
Batonio
1 Jun 2023 07:42
Thank you for the tips on drilling accuracy!
gadalu schrieb:
I use a drilling jig or a right-angle guide on the cordless drill [...] mark the depth with tape
I definitely plan to do it that way. Do you have any experience with how stable a plug-in system with metal brackets is under normal residential load? Would a Kallax also hold up in the long term if I attach the brackets not only to the front but also to the back panel?
Is that mechanically reasonable, or is there a risk that the board will weaken too much from the drill holes?
gregto
1 Jun 2023 08:15
Batonio schrieb:
Would a Kallax also hold up in the long term if I attach the brackets not only at the front but also on the back panel?
That’s a good idea! Especially with wider shelves, it significantly increases stability. However, before drilling, check whether the back panel itself is sturdy enough; Kallax often uses only thin hardboard.
Important: Avoid making too many holes close together – the wood can tear out or split.
Conclusion: Yes, fixing on the sides and back is sensible, but proceed carefully. If you add extra wooden strips as reinforcement, you can further improve the load capacity.
joro10
1 Jun 2023 09:31
I created a plug-in system with small metal brackets for my Kallax. They hold really well, but only if the holes are drilled precisely. I always use drill bits with a depth stop; otherwise, the holes can easily end up too loose or too tight.
Trate47
1 Jun 2023 21:57
That sounds like a cool project! I think the Kallax really gains flexibility through modular systems. Especially when you want to rearrange compartments spontaneously, it’s really practical.
I haven’t built a modular system myself yet, but regarding stability: Everything you do yourself will give a great DIY feeling – and every little hiccup becomes part of the story ;-)
Suggestion: Make a small sketch, carefully mark all the drill holes – then you’ll see how it looks in real life. I’m looking forward to hearing if you update us later! 🙂
lubla
2 Jun 2023 06:38
If you want to install the plug-in system into the Kallax later, I recommend adding guides to the side panels. This prevents any shifting. Important: Use wood glue for securing, as it increases durability.
