ᐅ Who here has ever had to replace Kallax shelves?
Created on: 16 Oct 2022 08:37
fa-matthia
I have a rather technical question regarding the popular IKEA Kallax shelving system: Has anyone here ever needed to replace Kallax boards? Specifically, I’m interested to know if anyone has figured out which types of screws or adhesives work best for the fixed connections, what alternative materials could be used for the boards, or if it only makes sense to repair it by replacing the entire unit.
I’m asking because a few of my boards are slightly damaged in some spots, and I’m unsure whether a partial replacement makes sense technically and economically—especially concerning load-bearing capacity and appearance.
Are there any recommendations for tools or techniques to replace Kallax boards yourself without having to dismantle the entire unit?
I look forward to your experiences, tips, or warnings if anyone has done such repairs before. Thanks!
GALENKU
17 Oct 2022 07:44
I have replaced individual boards before, but only by cutting them myself using materials from the hardware store. I applied edge banding and screwed them in – it held perfectly. So yes, it works if you work carefully.
EDWARD0
17 Oct 2022 09:26
I would use standard particle board and make sure the dowel joints fit well. Be sure to sand the edges smoothly and seal them properly.
liskar
17 Oct 2022 09:34
EDWARD0 schrieb:
Make sure to sand and seal the edges thoroughly
Exactly. This is essential because the edges of particle boards are particularly vulnerable. Otherwise, shrinkage due to moisture is likely.
