ᐅ Has anyone ever decorated their Kallax using decoupage?
Created on: 10 Mar 2020 14:37
Teofar
Teofar
10 Mar 2020 14:37
I have been thinking for a while about customizing my IKEA Kallax shelf to make it more unique and creative. I am especially interested in découpage techniques because they offer versatile design options and seem relatively easy to apply.
So I would like to ask the group: Who of you has already decorated your Kallax shelf using découpage? How did you proceed, which materials did you use, and what should be considered to achieve a good result?
I am also interested in your experiences regarding the durability and maintenance of surfaces treated with découpage – does it hold up well, or should one expect to apply an additional sealant?
I look forward to your tips, suggestions, and perhaps also critical feedback pointing out common mistakes. Thanks in advance!
eldubi
10 Mar 2020 15:03
I decorated my Kallax using decoupage with napkins. It’s important to sand the surface well and treat it with a wood primer. Apply napkin glue, carefully place the napkin, and then apply a clear varnish on top. This way, it will last a long time.
Ernesto
10 Mar 2020 16:47
For a reliable result with the decoupage technique on Kallax, I recommend planning the process very carefully.
First, sand the surface: I personally use fine sandpaper (grit 220) to slightly roughen the surface. Then treat the area with a primer (e.g., acrylic primer). It is important to apply the napkins with the thinnest possible layer—the lower layers of the napkin must be removed to avoid unwanted paper textures.
For adhesive, special decoupage glue or a matte Mod Podge works well, as these remain transparent and flexible when dry. When applying, be sure to gently press the napkin with a piece of cling film or a soft brush to avoid wrinkles.
After drying, sealing with a clear acrylic varnish is recommended, especially on areas that are frequently used, to protect against scratches and moisture. I suggest up to three layers of varnish, lightly sanding in between.
One more tip: Not every napkin is suitable. Colored and thin designs are easier to work with than very thick or heavily textured materials.
How exactly do you want to decorate the Kallax? Just the doors or the open shelves?
Teofar
11 Mar 2020 10:18
Ernesto schrieb:
Not every napkin is suitable. Colored and thin patterns are easier to work with than very thick or heavily textured materials.
Thanks for the detailed information, I will keep the napkin tip in mind.
I mainly plan to decorate the white back panels of the open shelves – so not the doors, but the inside surfaces of the compartments, to give the Kallax a personal touch without affecting its functionality.
Do you or anyone else have tips on how to best blend the transition between the napkin and the surface to prevent peeling or visible edges?
Also, how durable are the results under stress from storing books or decorative items? This is an important factor for me since the shelves are used a lot.
V
Victor54
11 Mar 2020 11:05
Teofar schrieb:
Do you or anyone else have tips on the best way to create a smooth transition between the napkin and the surface?
I would cautiously point out that with this technique, changes in the material unfortunately aren’t completely seamless. Napkin technique often results in slight elevations due to the layers of paper and glue, which don’t entirely disappear even after multiple layers of varnish.
The advantage lies in the visual effect, but if you’re looking for an absolutely smooth surface, you might want to consider films or printed veneer instead. Additionally, durability is questionable since moisture and mechanical stress can damage the edges of the napkins over time, even with varnish protection.
One question: Have you already tested how the surfaces of your Kallax react to moisture? The original coating is melamine and quite smooth – that can affect the adhesive’s bond.
Ernesto
12 Mar 2020 09:43
Victor54 schrieb:
Decoupage technique often results in slight elevations due to the layers of paper and glue
That’s correct, the surface becomes slightly textured, but this can be greatly reduced by using very thin decoupage paper and careful pressing.
Regarding adhesion on melamine-coated surfaces: I personally always sand the area to be treated very carefully with fine sandpaper to slightly roughen the smooth surface. Without this preparation, the glue does not adhere well.
To protect against moisture and abrasion, I use special clear varnishes designed for wood and furniture applications. After applying 1-2 coats, you can gently sand the surface and then apply another coat, which ensures good durability.
Teofar schrieb:
How durable are the results under stress from storing books or decorative items?
In this case, the sealant is indeed the most important element. Without clear varnish, the surface changes quickly and becomes more prone to scratches. Overall, decoupage technique is mainly suited for decorative surfaces that are not subjected to frequent mechanical stress.
