ᐅ Which water softener system should I choose? I’m having trouble deciding.
Created on: 13 Mar 2021 08:27
Palme23
Palme23
13 Mar 2021 08:27
Construction is progressing, and now we need to choose a water softener system. We are a household of four people with two bathrooms. I have looked into the following brands:
Judo model Softwell P (Duplex) or S (Simplex)
BWT Perla Home (Simplex)
Grünbeck SD18 (Simplex)
What would you recommend? Any other alternatives?
MayrCh
13 Mar 2021 10:49
All good manufacturers. Personally, I would always choose a two-column model, but the market seems to have developed differently over the past few years. Which manufacturer does your plumber install/maintain?
Bookstar
13 Mar 2021 10:50
MayrCh schrieb:
All good manufacturers. Personally, I would always choose a two-column system, but the market seems to have developed differently in recent years. Which manufacturer does your plumber install/service?
Why opt for a two-column system in a single-family house?
MayrCh
13 Mar 2021 11:05
Bookstar schrieb:
Why two columns in a single-family house?
There are no "hard" reasons. As a process engineer, I am intrigued by the engineering approach of a two-column system. Operating in parallel means a larger filter cross-section, lower pressure loss, reduced filtration velocity, and therefore a smaller mass transfer zone. All of this leads to higher capacity and more efficient operation. However, from an economic perspective, this is negligible. Hence the trend towards single-column systems.
HilfeHilfe
13 Mar 2021 13:23
I would buy what is common and can be maintained by the plumbing professional.
Palme23
13 Mar 2021 13:57
As mentioned, the plumber can provide and maintain all three. Their prices are also quite similar. I believe the BWT is the most expensive. I just don’t know how to choose.
