Hello
I am getting a Tesla Model 3.
Which wall box would you recommend?
The wall box would be mounted outdoors at the parking space (no garage, no carport).
I have the following questions:
Should I choose a wall box with a fixed cable or one with a socket (but with a lockable cable)?
Should I choose a wall box with up to 22 kW or just 11 kW?
What additional features should a wall box offer?
The wall box must have RFID security (it will be outdoors and accessible to everyone) and must include all safety mechanisms, such as DC fault protection.
Can you possibly recommend a wall box?
Three weeks ago, I had an ABL eMH1 wallbox installed.
It was the ADAC test winner and, due to KfW funding, limited to 11 kW (900 euros funding is not available for 22 kW) – but that still allows for roughly 70 km (43 miles) of range per hour of charging. Or 8 hours to fully charge.
The unit is secured with a key switch, has an integrated residual current device (RCD), and the circuit breaker panel already included a dedicated RCD for the cable. The protection rating is IP54, so it is suitable for outdoor installation.
There are also third-party metal canopies available that can be mounted above it, offering some additional protection for the wallbox.
It was the ADAC test winner and is limited to 11 kW (900 euros grant is not available for 22 kW) due to KfW funding – but it still charges at about 70 km (43 miles) range per hour. Or about 8 hours to fully charge.
The box is secured with a key switch, it has a built-in residual current device (RCD), and there was already a dedicated RCD in the fuse box for the cable.
The enclosure rating is IP54, so it’s suitable for outdoor installation.
There are also third-party metal canopies available that can be mounted above it, providing some additional protection for the wallbox. I just checked it out. Delivery times on five different sites are all 30 weeks or more :-)
Pacc666 schrieb:
Thanks, I’ve already seen the ABL, but unfortunately it doesn’t have RFID. Ok, but what do you need RFID for? Multiple users with separate billing? Or just access control—for the latter, the lock alone is usually sufficient.
Pacc666 schrieb:
What does it look like? Are you worried about vandalism, like someone cutting the cable or damaging the box? There are also boxes with separate cables. Damage? That’s an issue with any box, it depends on your environment. For us, I considered the lock more as a necessity because of playing children and similar reasons—the charging point is located on a private road/accessway.
