ᐅ Which types of wood are suitable for a DIY Ikea Platsa conversion?
Created on: 7 Jul 2024 09:13
gulosoHello everyone, I am considering modifying my Ikea Platsa wardrobe to better suit my individual needs. I plan to replace the outer panels and some inserts with different wood to improve both the appearance and stability. My main question is about which types of wood are best suited for a DIY modification of the Ikea Platsa. Important factors for me are ease of workability, load-bearing capacity, appearance, and of course compatibility with the existing Ikea materials, especially regarding fastenings and adjustments. Does anyone have experience with specific wood types that work particularly well or even tips for surface treatment? Thanks in advance for your detailed opinions and recommendations!
Nathanaelk7 Jul 2024 11:46That’s an interesting question, since the Platsa cabinet from Ikea is primarily made of particleboard or melamine-coated panels, which are both affordable and functional. If you’re looking for replacement wood for a DIY conversion, I would recommend solid wood types that are relatively easy to work with and still sufficiently stable.
- Beech: The wood is hard, dense, and has a nice, light color. It sands and paints well, which is an advantage for the finish. When drilling and screwing, it remains stable without splintering.
- Pine: Softer than beech but easier to work with. Ideal if you plan to adjust the cabinet later. However, you should expect some vulnerability to dents.
- Plywood panels (e.g., birch): Very suitable for furniture and conversions. They are stable, comparatively lightweight, and have a nice surface that looks good with clear varnish. Edging is also possible.
For compatibility with Ikea’s connector systems, you should use panels with the same or similar thickness (Ikea uses 16 mm (0.63 inch) as a standard). Especially with solid wood or plywood, you often need 18 mm (0.71 inch) panels, which can cause problems with the connectors. Here I recommend either adjusting the connection details or considering modifications with flat dowels or cam locks.
One last tip: The type of surface treatment depends on how the cabinet will be used. For the exterior of the cabinet, a lacquer or wood oil finish makes sense. If you’re doing the conversion for indoor use, stains or glazes can often be used instead.
What are your priorities regarding stability versus appearance? And do you want the wooden parts painted or left natural?
after having modified several smaller IKEA furniture pieces, I can share the following from my experience:
- Pine wood is often my favorite due to its availability and low cost. It is easy to work with and accommodates a wide range of screws and dowels. It is important to prepare carefully to prevent the wood from splitting.
- If you value a refined finish, birch plywood is a good choice; the surface looks high-quality and sturdy. Plywood also has the advantage of being quite durable thanks to its multiple layers.
- Pay attention to thickness differences: IKEA Platsa usually uses 16 mm (5/8 inch) panels; if you come from 18 mm (3/4 inch) plywood, more extensive adjustments will be necessary.
- For example, if you plan doors or cutouts, it is advisable to work precisely before assembly to avoid cumulative inaccuracies later on.
- For fastening, it is recommended to use specialized wooden dowels and appropriate screws, as IKEA connectors are not always compatible with solid wood.
One last tip: let the wood acclimate for at least 2 days after cutting, especially with solid wood, to prevent warping.
If you want to know more about selecting essential tools for such modifications, I am happy to explain that as well.
When choosing wood types for the Ikea Platsa conversion, the following criteria should be especially considered:
- Material thickness: The original panels are 16 mm (5/8 inch) thick, which is important for the fit of connection elements.
- Load capacity: Harder woods, such as beech, offer higher load-bearing strength, which is beneficial for heavy shelves.
- Workability: Plywood panels, especially birch, are fiber-reinforced and allow precise cutting without fraying.
- Appearance: Depending on the desired surface, you can choose between solid wood finishes, painted veneers, or oiled panels.
A combination of plywood as the load-bearing material with veneered solid wood glued on can be a good solution when stability and design need to be combined.
Please also note that using original Ikea fittings often requires adjustments if the material thickness or structure differs.
Nathanaelk9 Jul 2024 10:07Joshbe schrieb:
Please also note that using original Ikea fittings often requires adjustments when material thickness or structure differs.This is a key point. Connection systems are specifically designed to match the material and its dimensions. For example, if you use 18mm (0.7 inches) plywood, the standard connectors may no longer fit precisely.
Another tip: when working with solid wood, you can use washers on the inside to stabilize the screws, as solid wood has a different screw-holding strength compared to particleboard.
When choosing wood types, keep in mind how the material reacts to changes in humidity. Solid wood expands and contracts significantly more than MDF or particleboard, which could affect joints and fit over time.
Therefore, during remodeling, it’s best to measure all materials accurately beforehand and make small test pieces to see how the connections behave with your chosen wood.
