ᐅ Which types of wall anchors are most secure for mounting IKEA Besta units?
Created on: 9 Feb 2020 18:37
Lau-zar
Lau-zar
9 Feb 2020 18:37
Hello everyone, I am planning to securely attach an IKEA Besta sideboard to the wall and would like to know: Which types of anchors are especially reliable for mounting the IKEA Besta to walls, particularly with different wall materials like concrete, brick, or drywall? I have come across various anchors such as universal anchors, heavy-duty anchors, and cavity anchors, but I am unsure which ones really offer the best holding strength and ensure long-term stability. Any recommendations on suitable screws and installation tips would also be very helpful, so that the construction is not only secure but also durable. Thanks in advance for your opinions and experiences!
glapu
9 Feb 2020 19:02
For concrete walls, heavy-duty anchors are best as they provide maximum security. For brick walls, universal wall plugs work well if installed correctly. For drywall, I recommend using specialized hollow wall anchors that expand behind the panel. It is always important to use the appropriate screws.
Ernesto
10 Feb 2020 09:14
Hello Lau-zar, to answer your question in detail, I will address the main types of anchors and their suitability. First of all, the wall material is crucial for choosing the right anchor:
- Concrete: Heavy-duty anchors (also called bolt anchors) are the top choice here. They provide high load-bearing capacity because they anchor deep into the material and handle tension forces very well. Universal anchors can work but have significantly lower safety margins.
- Brick walls: Universal anchors with a wide expansion range are recommended here, ideally combined with slotted screws for better fine adjustment. It is important to pre-drill and use anchors with a sufficient diameter (e.g., 10 mm (0.4 inches)).
- Drywall (plasterboard): Thin panels can only support light loads using special cavity anchors. Toggle, spring, or flip anchors distribute the load behind the panel. For the Besta cabinet, which has a moderate load, cavity anchors should be dimensioned generously.
Installation tips:
- Always clean out drill holes thoroughly.
- Adjust screw length to the anchor and material so that the anchor is fully engaged.
- Do not insert anchors too deep to avoid reducing holding power.
Additionally, for cabinets like Besta, which are often loaded with weight such as media equipment, it is advisable to use several anchors in concrete or brick strategically and distribute the load. If your wall is drywall and will be loaded, you should add a steel bracket or fix the mounting onto load-bearing points (studs) behind the drywall, which greatly improves safety.
One more question: Do you know if your wall is purely drywall construction or maybe has a load-bearing back panel? This can further affect the anchor choice.
Landontau
10 Feb 2020 11:07
Ernesto schrieb:
- Drywall: The thin panels can only support light loads with special hollow wall anchors. Toggle, spring-loaded, or tilt anchors distribute the load behind the panel.
You summarized that very well! I would like to add that especially with drywall, the distance to the load-bearing wall is crucial – the larger the cavity, the more expansion volume is needed for the anchors.
Additionally, when mounting IKEA Besta units, if possible, I recommend anchoring the metal frame of the furniture into the wall with anchors rather than relying solely on the back panel, as the latter is often made of thin, lightweight material.
Other important points:
- Drill the holes with the correct drill bit to ensure the anchor grips properly.
- Use anchors that match the wall type, not just whatever is available.
For concrete and solid masonry, heavy-duty anchors, such as frame anchors or metal expansion anchors, are ideal since they develop their full holding power as they are screwed in.
Summary:
- Concrete: Heavy-duty anchors (frame anchors)
- Brick: Universal anchors with a larger diameter
- Drywall: Hollow wall anchors (toggle or spring anchors), ideally with additional reinforcement
If you like, I can also send you a short checklist for the installation!
