ᐅ Which types of screws are particularly durable for Billy shelves?
Created on: 24 Jan 2016 09:23
Deola
Deola
24 Jan 2016 09:23
I am planning to assemble several Billy shelves from IKEA and want to pay special attention to the durability of the fastenings this time. My specific question is: Which types of screws, either original IKEA ones or those available at hardware stores, are particularly durable and provide a stable and long-lasting connection for the typical wooden or metal parts of Billy shelves?
I am especially interested in screws that not only hold well but also resist rust and material wear over time, as I have often experienced that screws start to rust or loosen after a few years.
Does anyone have experience with alternative screw types or materials that work especially well for Billy shelves? What are the advantages and disadvantages associated with the different types? I look forward to a detailed and knowledgeable discussion, as a sustainable solution is very important to me. Thank you in advance!
RON57
24 Jan 2016 09:47
Hello Deola,
Basically, IKEA uses standard chipboard screws or Minifix connectors for Billy shelves. For a more durable solution, you should opt for galvanized or, even better, stainless steel screws. These are rust-resistant and handle moisture much better.
Deola schrieb:
Which types of screws, available either originally from IKEA or at hardware stores, are especially durable and provide a stable and long-lasting connection for the typical wooden or metal parts of Billy shelves?
For the wooden parts, I specifically recommend countersunk screws with partial threading, as they clamp the wood more effectively. Alternatively, screws with locking threads—so-called self-locking screws—are a good idea if vibrations are expected, since they prevent loosening.
It is also important to pay attention to the appropriate screw diameter. Screws that are too thin might loosen more quickly. I usually use 4mm (5/32 inch) diameter screws for Billy shelves, which are sturdy yet gentle on the material thickness.
Additionally, you can apply small spots of wood glue to further stabilize the connection.
I hope this helps as a first overview!
BLAKEO
24 Jan 2016 10:13
I would like to offer a different perspective here:
RON57 schrieb:
For a particularly durable solution, you should use galvanized or better yet stainless steel screws. These are rust-resistant and handle moisture much better.
This is generally true, but stainless steel screws are not unbeatable in terms of strength, nor are they always the best choice in this context. For example, stainless steel screws can actually cause damage to softer materials like the particleboard wood used in Billy shelves if the screws are too rigid and not handled carefully.
In my opinion, it’s much more important that the screw thread matches the material, and that the screw itself is neither too fine nor too coarse, but instead grips optimally—especially with a material like wood that is also coated.
Also, the topic of joining techniques shouldn’t be limited to screws alone. If durability is important in a Billy shelf, you might want to consider combining different joining methods or additionally using dowels or wood glue.
So my question to everyone is: Are there any experiences indicating that not just the type of screw, but the overall connection concept plays a bigger role? Or are we focusing only on screws here, even though other solutions might be better?
Connor
24 Jan 2016 11:05
I’m already looking forward to this discussion, especially since I generally consider Billy shelves to be a highly overrated design.
Deola schrieb:
Which types of screws, either original from IKEA or available at hardware stores, are particularly durable and provide a stable and long-lasting connection for the typical wood or metal parts of Billy shelves?
In short: No matter how much money you spend on supposedly high-quality screws, the Billy shelf remains a construction made of thin particleboard and laminated panel material, which simply isn’t designed for heavy loads over time. The screws are the lesser issue.
Where exactly do you expect the durability to start?
If the furniture is intended to be used for a few years, the original screws are usually sufficient. If you want a piece that lasts a lifetime, I recommend choosing completely different materials and avoiding anything that involves particleboard.
My provocative thesis: For furniture in this price range, any discussion about screw types is ultimately irrelevant as long as the base materials are not of higher quality.
Noahlu
25 Jan 2016 07:38
I would like to build on Deola’s question and add some technical details.
First of all, several factors affect the durability of screws in Billy shelves:
1. Screw material: Stainless steel screws are rust-resistant, but there are different stainless steel grades. A2 (V2A) is corrosion-resistant and perfectly adequate for typical indoor environments, while A4 (V4A) is even more durable but significantly more expensive. Zinc-plated screws are affordable and sufficiently protected, but usually not as long-lasting as stainless steel in humid conditions.
2. Thread type: For connecting wood or particleboard panels, coarse threads are recommended as they grip better and are less likely to strip. At the same time, the screw should have an appropriate length to anchor firmly in the wood.
3. Pilot holes: Especially with chipboard or coated surfaces, drilling pilot holes is advisable to avoid damaging the material. This prevents cracks and results in stronger joints.
4. Type of load: Cross-loading is common in Billy shelves, so screws with locking threads or self-locking features, such as hex screws with locking notches, which loosen less easily, can be helpful.
5. Coatings and surface finish: For the screw’s seating area, it is advantageous if the surface is smooth without sharp edges to avoid additional stress on the wood material.
Therefore, my recommendation is to use A2 stainless steel screws with coarse threads, pay attention to the correct length (usually around 35–40mm (1.4–1.6 inches) for Billy shelves), and drill thin pilot holes before screwing in. Additionally, a small drop of wood glue at the joints can provide extra stability.
Finally, a question for Deola: Do you use the shelves in a normal residential environment or rather in damp rooms? This can influence the choice of suitable screws.
