ᐅ Which types of paint are best suited for Ikea BESTA furniture?
Created on: 26 Apr 2022 19:23
ru_bar
ru_bar
26 Apr 2022 19:23
I am currently considering upgrading my Ikea Besta furniture by repainting it myself. Since I want to improve both the appearance and durability, I am wondering: which types of paint work best on Ikea Besta furniture, especially considering the materials involved (mostly MDF with foil coating or melamine surface)?
I’m particularly interested in knowing which paints adhere well, are long-lasting, and possibly offer some flexibility to prevent the finish from chipping quickly. I am also curious about the best way to prepare and apply these paints, as Besta furniture has different surface types. My goal is not a simple spray paint but a higher-quality and more durable finish that also holds up well on the edges.
I look forward to hearing about experiences or recommendations from the community, preferably with a brief explanation of why certain types of paint are especially suitable or not. Thanks in advance!
Takutau
26 Apr 2022 20:14
Hello ru_bar,
First of all: Ikea BESTA furniture is often made of particleboard or MDF, coated with melamine or foil surfaces. This strongly influences the choice of paint.
In general, I recommend acrylic or alkyd paints, as they adhere well and are durable when applied. However, it is crucial to properly prepare the surface before painting.
- Start by lightly sanding the surface with 180 to 220 grit sandpaper to dull the smooth foil or melamine.
- Then use a high-quality primer to improve paint adhesion.
- Make sure the materials are solvent-resistant—alkyd paint is usually more durable but also has a stronger odor.
- For DIY users, acrylic or water-based paints are easier to work with, have low odor, and provide good coverage.
Regarding the edges: The biggest challenge is often that they are made from different materials than the surfaces, which requires additional preparation. A primer helps here as well.
It’s best to test on a small area first to check adhesion and appearance.
naujon
27 Apr 2022 10:55
I would like to organize my response a bit to give you, ru_bar, a clear overview.
1. Understanding the material
Ikea BESTA furniture is usually made of particleboard or MDF with foil or melamine coatings. These coatings are very smooth, so raw paint will hardly adhere without proper preparation.
2. Preparation
- Sanding: It is important to lightly sand the surface with fine sandpaper (around 180-220 grit) to roughen it up.
- Cleaning: Remove dust and degrease the surface.
3. Primer
- Use special adhesion primers, such as acrylic-based bonding primers or synthetic resin primers, to ensure a good bond with the plastic surface.
4. Types of paint
- Acrylic/water-based paints: Environmentally friendly, low odor, suitable for indoor use.
- Synthetic resin paints: Especially durable and glossy, ideal for furniture.
- Two-component (2K) paints: Very robust, but recommended only for professionals.
5. Application
- For an even result, spray painting or fine brushing/rolling is recommended.
- Apply several coats with light sanding in between.
Summary:
Acrylic synthetic resin paints combined with the appropriate primer are optimal.
Common mistakes:
- Not using a primer
- Not sanding the surface
- Applying paint too thickly
I hope this helps you!
RonJarrett
27 Apr 2022 14:37
It should be noted that Ikea BESTA furniture, due to its foil or melamine coating, presents a challenging surface for paints. The durability of the paint primarily depends on proper surface preparation.
Conclusion:
- Primer is essential
- A standard acrylic or alkyd paint is recommended
- Alkyd paint offers better resistance to scratches and wear
Additionally, I recommend keeping the painting environment dust-free and maintaining a suitable room temperature. Low temperatures or high humidity can cause problems with paint drying.
Important: Ideally, avoid using spray paints, as they often result in uneven application on large surfaces.
Jaime
27 Apr 2022 18:02
Additionally, I would like to note that when choosing paint for Ikea BESTA furniture, post-treatment should not be overlooked. A clear coat, such as a water-based acrylic varnish, can further protect the surface and extend its durability.
During application, it is essential to observe the drying time, as wet paint can be easily damaged.
Summary:
- Acrylic paint as a base coat
- Clear coat as a protective layer
- Always use a primer beforehand
This results in a long-lasting and visually appealing finish.
Ellis
28 Apr 2022 08:11
For BESTA furniture, I recommend water-based acrylic paints. Don’t forget to apply a primer first. This ensures good adhesion and a smooth finish.
