ᐅ Which type of screws is most suitable for Ikea Hemnes furniture?
Created on: 20 Feb 2022 09:22
nejan0
nejan0
20 Feb 2022 09:22
My question is: Which type of screws is especially suitable for assembling the Ikea Hemnes furniture series? I plan to assemble a Hemnes bed and possibly some cabinets myself and want to make sure I use the right screws that provide the necessary stability without damaging the wooden parts. I am also interested in whether the original screws can be replaced by other types to improve the structure’s durability or strength. Are there any recommendations regarding screw type, material, length, or head style that make particular sense for the Hemnes series, or any experience with alternative options that have proven effective?
KARJU
20 Feb 2022 11:07
The Hemnes series from Ikea primarily uses coarse-thread chipboard screws because the furniture is made of painted solid wood or coated wood-based materials. For assembly, screws with the following characteristics are suitable:
- Material: Galvanized steel to prevent corrosion
- Thread: Coarse thread to ensure good grip in the wood without splitting the material
- Head: Countersunk head to sit flush with the surface
- Length: Usually between 30 to 50 mm (1.2 to 2 inches), depending on the component and the thickness of the wood panels
The original screws are generally designed to hold the joints securely while protecting the wood. If replacements are needed, Spax or similar wood screws with comparable dimensions are recommended. It is advisable to avoid screws that are too long or too thick, as this can affect stability or enlarge the holes.
Finally, screws should always be driven in slowly, and pre-drilling is recommended if necessary to protect the wood.
Surela
21 Feb 2022 14:36
KARJU schrieb:
The original screws are usually designed to hold the joints securely while protecting the wood at the same time.
I fully agree with this and would like to elaborate further. The Hemnes series, due to its solid wood content and relatively soft surface, is particularly sensitive to unsuitable screws. It is important to consider not only the material but also the type of screw:
- Chipboard screws with coarse threads are ideal because they displace the wood less, which helps prevent splitting.
- Stainless steel or galvanized screws are preferable to avoid rust and consequent damage.
- A countersunk head is practical so the screw sits flush, preventing damage to the surface.
I also recommend:
1. Drilling a pilot hole before screwing, about 70-80% of the screw shaft diameter, depending on screw thickness, to relieve stress on the wood.
2. Using lower torque when driving screws in load-bearing parts to avoid damaging the threads.
3. Whenever possible, use the original connection fittings and only replace screws if they are damaged.
Could you specify which Hemnes parts you plan to assemble? This would help determine the precise length and thickness of screws needed.
nejan0
22 Feb 2022 08:50
Surela schrieb:
Can you specify which Hemnes parts you plan to assemble? That will help determine the exact length and thickness of the screws needed.
I will mainly be assembling the Hemnes bed 160x200 cm (63x79 inches), where the headboard, footboard, and side rails are connected. Additionally, I plan to assemble the Hemnes wardrobe with five doors. It would be practical if the screws could be suitable for both applications or if there are at least recommendations for differences. I have read that longer screws can sometimes be useful for stabilizing bed frames, but I want to avoid damaging the wood. Therefore, I am interested in advice on which type of screws (material, length, thread) are recommended for frame constructions in the Hemnes bed and which are suitable for the furniture doors on the wardrobe.
SauDietmar
23 Feb 2022 07:33
nejan0 schrieb:
I will mainly assemble the Hemnes bed 160x200 cm (63x79 inches), where the headboard, footboard, and side panels are connected. Additionally, I plan to install the Hemnes wardrobe with five doors.
Here is a structured overview to help you choose the right screws for both types of furniture:
For the Hemnes bed 160x200 cm (63x79 inches):
- Recommended screw type: coarse-thread particle board screws
- Length: 50 mm (2 inches) is suitable for frame and crossbars
- Material: galvanized or stainless steel for durability
- Head: countersunk head, flush recessed
- Recommendation: pre-drill with a 3-4 mm (0.1-0.15 inch) drill bit, drive in slowly to avoid splitting
For the Hemnes wardrobe (special consideration for doors):
- Doors are usually attached with Lamello screws/connectors and use smaller particle board screws
- Screw length: 30-40 mm (1.2-1.6 inches) is usually sufficient
- Material: galvanized steel is adequate
- Important: do not tighten screws too much, as fittings can break or the wood can split
A small tip at the end: If you are looking for higher-quality replacement screws, commonly available Spax screws in the mentioned lengths and specifications offer a reliable alternative, as long as the wood is not heavily stressed. However, too wide or too long screw heads can damage the finish.
I hope this structured summary helps you.
