ᐅ Which tools should I not forget when assembling Ikea PLATSA?
Created on: 5 Jan 2023 08:37
TANER66
TANER66
5 Jan 2023 08:37
Hello everyone, I am currently planning the assembly of my new Ikea Platsa modular system and want to make sure I have all the necessary tools ready to make the process as smooth as possible. My specific question is: Which tools should you absolutely not forget when assembling Ikea Platsa? I understand that the frame is assembled with screws and wall plugs, but does anyone have experience with tools that are often overlooked yet very helpful? Tips on different screw types, drilling, adjustments, or assembly steps are also welcome so I can be optimally prepared.
Bilujon
5 Jan 2023 09:12
For Ikea PLATSA, you definitely need a Phillips screwdriver, preferably with a comfortable grip. Additionally, a cordless drill is helpful to save effort and time. A small hammer can also be useful in case dowels need to be tapped in.
Tevin
5 Jan 2023 10:05
Hello TANER66, I think your question is very well put, as it helps avoid constantly searching for tools during the build. Besides a Phillips screwdriver and a cordless drill, I also recommend a spirit level to make sure everything is hung straight. A measuring tape or ruler is also useful to check distances. If you need to drill into walls, you should have a suitable drill bit – usually 6 to 8 mm (0.24 to 0.31 inches), depending on the type of anchors used. A small set of Allen keys is usually included with PLATSA, but it’s good to have your own set on hand in case something gets lost.
Cecilera66
5 Jan 2023 10:48
Don’t forget: a rubber mallet or a small rubber hammer for delicate cabinet parts. This helps prevent dents when driving in dowels or adjusting side panels. Otherwise, as already mentioned, a Phillips screwdriver and a cordless drill.
Timmyse36
5 Jan 2023 11:26
I completely understand how frustrating it is to realize in the middle of construction that a tool is missing. I experienced that once with the spirit level! I would recommend going through everything in advance and also having a small screwdriver set ready, in case there are special screws or unusual fasteners. And be patient – the system is smart, but it takes time 🙂
Dopoki
6 Jan 2023 07:54
As an addition: A common issue with the PLATSA system is the correct alignment and precise insertion of the wooden dowels. Therefore, I recommend using, alongside standard tools, a protractor or a small stop block. This improves the fit accuracy and increases the furniture’s load-bearing capacity. It is also advisable to use screwdrivers or bits with a magnetic tip so that the screws do not fall off the tool during insertion.
