Hello everyone, I have a problem with a few Billy shelves that I have owned for years. Specifically, it concerns the repair or stabilization of shelf parts where holes have been worn out or dowels have broken. My question is: Which tools, aids, or special equipment can truly make repairing Billy shelves easier, so I can restore the shelves to be stable and load-bearing again? I look forward to your experiences and tips, including any simple tricks that might not be obvious at first glance. Thanks in advance!
Hello Jamal9,
Regarding your question about wood filler: Not every wood filler is suitable for this purpose. For durable repairs, it is recommended to use fillers that do not become too brittle after drying and that are easy to sand.
The method is actually quite simple: First, clean the hole from any loose particles. Then apply the filler generously, completely filling the hole. Important: Don’t apply it too thinly, so there is enough material to create a strong hold.
Once the filler has dried (depending on the product, several hours), lightly sand the surface and drill a new, accurately sized hole for the anchor.
For the anchor, I recommend coating it with wood glue before insertion, which improves the mechanical bond.
My tip: Let it dry thoroughly overnight because screwing too early can compromise stability.
What do you think, or do you already have a wood filler in mind?
Jamal9 schrieb:
How exactly do you use wood filler for holes so that the anchors really hold?
A small addition to the important advice from faso31:
This is really crucial. Also, when sanding, you should use fine sandpaper to avoid removing too much material. Otherwise, the stability will decrease again.
And one more tip that beginners often overlook: it’s best to test the anchors and screws in a less visible spot first. This way, you can check if the repair holds before putting weight on the entire shelf.
I wish you good luck – having the right tools often makes the job much easier. :-)
faso31 schrieb:
Do not apply the filler too thinly
