Hello everyone, I would like to start a practical discussion on the topic: Which tools make maintaining IKEA Besta furniture easier? Specifically, I mean tools that help with tightening screws, adjusting doors, replacing hinges, or repairing damage on this modular furniture. I'm not referring to assembly, but rather the long-term care and maintenance. I would also like to know if there are any special aids beyond standard tools that can help – perhaps extras that simplify the process or prevent damage. Thanks for your insights and practical tips!
JULIANNALO5 May 2021 10:14For maintaining Besta furniture, typically a Phillips screwdriver and an Allen key of the appropriate size are sufficient. These two tools cover most screws. A spirit level is helpful for adjusting and aligning doors precisely.
A structured approach helps with the maintenance of IKEA Besta furniture:
- To tighten screws, a cordless drill with a torque controller is recommended to avoid damaging the screws.
- A set of various Allen keys makes it easier to adjust the doors and hinges, as Besta furniture often uses different screw sizes.
- Additionally, a small utility knife or blade cleaner is useful for cleaning seals or, if necessary, shelves.
- A set of flathead and Phillips screwdrivers designed for small tasks is helpful, as some fasteners are quite delicate.
Common mistakes include overtightening screws, which can damage the wood. Therefore, I recommend using a torque controller or proceeding carefully.
chenValeri5 May 2021 12:23In addition to the recommended tools mentioned, a small rubber mallet is very useful. It allows you to gently align parts or tap them in carefully without causing any damage.
To clarify: For the maintenance of IKEA Besta furniture, it is important to use tools with precisely matching sizes, especially for Allen keys (hex wrenches) and screwdrivers.
Recommendations:
- A ratchet or socket wrench with attachments for different screw sizes reduces fatigue and increases precision.
- Microfiber cloths for cleaning surfaces and edges before retightening screws help prevent damage caused by dust and dirt.
- For worn hinges, using a light lubricant (e.g., silicone-based) is recommended to maintain functionality.
An important note: Do not use power tools with excessive torque to avoid tearing the material or damaging screw heads.
Recommendations:
gekira schrieb:
For maintaining IKEA Besta furniture, it’s important to use tools with precisely fitting dimensionsThank you very much for the detailed advice. How exactly can I determine the correct sizes here? IKEA often doesn’t explicitly specify the dimensions of the hex keys or Phillips screwdriver types. Is it effective to measure them with calipers? Or are there common standards that are most frequently used based on experience?
