ᐅ Which tools make it easier to adjust Ikea BESTA doors and drawers?
Created on: 24 Jun 2022 08:14
ploanthony
ploanthony
24 Jun 2022 08:14
Hello everyone, I am currently facing the challenge of precisely adjusting IKEA Besta doors and drawers, as the alignment of my furniture has shifted over time. My question is quite specific: What tools and aids do you recommend to adjust the doors and drawers as accurately as possible and with minimal effort? I already have basic adjustment tools like screwdrivers and hex keys, but I’m also interested in special tools or techniques that can make the readjustment easier, especially for the hinges and slides. It would be great if you could also share practical experiences or tips related to the IKEA Besta series.
Repar
24 Jun 2022 08:43
To adjust the BESTA doors, I recommend a small Phillips screwdriver and an Allen key of the appropriate size. For the drawers, a small screwdriver is useful to adjust the screws on the slides. Special tools are not absolutely necessary; usually, the standard tools that IKEA most likely provides are sufficient.
Gafiel
24 Jun 2022 10:29
The question of which tools make adjusting IKEA BESTA doors and drawers easier addresses an important aspect of furniture functionality after extended use. Fundamentally, I want to point out that adjusting the hinges and drawer slides depends not only on the tools but also on an appropriate method.
For the doors, typical three-way hinges are installed, with screws used for fine-tuning the gap and alignment. Here is a brief overview:
- Phillips screwdriver (PH2) for the adjustment screws
- Allen key (often 4mm) for any embedded screws
- Possibly a small angle wrench for hard-to-reach screws
Additionally, I recommend a spirit level or a small straightedge to ensure that the doors, after adjustment, not only close properly but also hang horizontally. This is especially important for large doors, where uneven alignment noticeably affects the overall appearance.
The process is similar for the drawers:
- Fine adjustment is usually done on the sliding rails and on screws that align the front panel
- A small Phillips screwdriver is also useful here
For better handling, it makes sense to first loosen all screws securing the parts, then make the adjustments, and finally tighten everything securely again.
I would be interested to know the exact issues you’re experiencing. Are the doors hanging unevenly, or do they no longer close properly? Are there problems with the gaps or the smoothness of the drawer operation? With these details, more targeted tool recommendations and procedures can be suggested.
ploanthony
24 Jun 2022 13:08
Gafiel schrieb:
I would be interested to know exactly what the issue is in your case. Are the doors misaligned, or do they no longer close properly? Are there problems with the gaps or the smoothness of the drawer slides? With these details, it’s easier to recommend specific tools and methods.
Thank you for asking. The doors of my BESTA unit tend to bow slightly outward at the bottom and rub slightly when closing, which is probably due to imprecise hinge adjustment. The drawers still operate smoothly, but the fronts are no longer perfectly aligned with each other, which affects the overall appearance. That’s exactly why I’m looking for tools or small aids that allow me to make precise adjustments – ideally ones that are easy to use, since I’m not a professional tradesperson and don’t have specialized tools at home.
jeff65
24 Jun 2022 14:54
Based on the described issue, I recommend the following:
- A small Phillips screwdriver with an ergonomic handle allows for precise adjustment of the hinges.
- For the doors themselves, a small set of plastic spacers can help to set the gap optimally.
- A protractor or a more professional digital inclinometer is not absolutely necessary but makes alignment much easier.
The combination of good screwdrivers and measuring tools usually achieves the best results without the need for complex specialized equipment. It is also important to tighten the screws carefully and avoid over-tightening to prevent damage to the hinge adjustment mechanism.
Z
zarlu
25 Jun 2022 09:22
It’s interesting how everyone here immediately relies on screwdrivers and Allen keys – as if IKEA didn’t already include enough “branded tools,” like the plastic Phillips screwdriver in the package. My view: If you really want to make adjusting BESTA doors and drawers easier, you don’t need any additional tools, but rather patience, a methodical approach, and a bit of finesse.
jeff65 schrieb:
A protractor or a more professional digital inclinometer isn’t absolutely necessary but does make alignment easier.
I see it differently – professional measuring tools for such a simple piece of furniture are simply overkill. The very basic method with a few small, homemade aids (e.g., cardboard templates, a small ruler, and the edge of a table as a reference) is perfectly sufficient.
Besides, I believe that a too detailed tool list tends to confuse occasional DIYers. Sometimes, less is more.
