ᐅ Which tools make disassembling Malm furniture easier?
Created on: 30 Mar 2024 09:17
Mutebar
Mutebar
30 Mar 2024 09:17
I am currently working on disassembling Malm furniture and am wondering which tools really make the job easier. I’m interested not only in the obvious tools like screwdrivers or hammers, but also in specialized aids that make the process more efficient and gentle.
For context: Malm furniture often uses cam and minifix connectors, which can sometimes be quite stubborn to loosen. Additionally, some screws are unusually small or set deep into the material. I am therefore looking for tools that support both precise work and help avoid damage.
Do you have experience specifically with this furniture? Which screwdrivers or bits work well? Are there any practical tips or tools for removing snap-fit mechanisms or dowel connections? Perhaps even aids for better handling of the relatively large parts?
I look forward to a factual and detailed discussion, as I want to make the process as smooth as possible.
kulau
30 Mar 2024 10:42
Hello Mutebar,
you have summarized the issue very well, and I am quite familiar with the challenges of Malm furniture.
First, I recommend getting high-quality Phillips PH2 bits. These are standard for most Malm screws and important because cheap bits often slip and damage the screw heads. For tightening screws, I suggest a ratcheting screwdriver; it provides more torque and precise control without needing to reposition the screwdriver constantly.
For the cam lock fittings, it is important to use a small, flat tool to expose and loosen them. A special plastic cam lock removal tool can make loosening easier without damaging the material. T-shaped screwdrivers are also often recommended because they fit better into the unusual positions.
Since some dowels in Malm furniture can be quite tight, dowel puller tools or, even better, a multifunction tool set with small pliers that can grip the dowels from the top and gently pull them out without damaging the wood are worthwhile.
If you are moving larger panels, I advise getting helpers or at least using furniture dollies. The panels are large and rather heavy, so there is a risk of personal injury or damaging the material.
Before I make final recommendations, I would like to know whether you plan to partially disassemble the furniture or take it apart completely for moving. This affects the choice of tools, as full disassembly sometimes requires removing more screws than partial solutions.
Looking forward to your feedback.
BARSAN
30 Mar 2024 14:28
kulau schrieb:
For cam lock connections, it is important to use a flat, small tool to access and release them.
Use a good Phillips PH2 bit and a ratchet. For cam lock connections, a small flathead screwdriver often works well. Additionally, have a soft rubber mallet on hand in case something gets stuck. This is usually sufficient.
Blavin
31 Mar 2024 08:56
That is basically correct. Additionally, I would recommend using a magnetic bit holder. This helps to keep the screws more securely in place during loosening and tightening, preventing them from slipping.
For cam lock fittings, the standard eccentric connectors are designed so that a flathead screwdriver with a blade width of about 5–6 mm (0.2–0.24 inches) fits ideally. Cheap tools can break or slip here, causing damage.
Another very useful tool is a small wedge or a thin plastic spatula to carefully separate the boards without damaging the wood or surface. This is especially important for pressure marks or tightly fitting edges.
To prevent screw damage, a torque screwdriver is also recommended to avoid over-tightening the screws during assembly. This point is often underestimated and significantly increases the longevity of the furniture.
Finally, I would be interested to know which type of screwdriver you prefer – cordless or manual? That also makes a difference in how you handle the work.
