ᐅ Which tools make cleaning Ikea Metod glass fronts easier?
Created on: 30 May 2024 08:37
Minjesper
Minjesper
30 May 2024 08:37
Hello everyone, I would like to start a discussion on the topic "Which tools make cleaning Ikea Metod glass fronts easier?" I have a kitchen with glass fronts from the Metod series and have noticed that cleaning is not always straightforward—especially when dealing with fingerprints, dust, and stubborn stains. I am interested in which cleaning tools or aids are particularly recommended for both time-saving and gentle cleaning. Are there specific microfiber cloths, sprays, sponges, or perhaps practical gadgets that you use? It is important to me that the glass fronts are not damaged and that the cleaning process is as efficient as possible. What experiences have you had, and which tools can you recommend from your own practice?
dijan
30 May 2024 09:12
Hey Minjesper! I also have a Metod kitchen with glass fronts and swear by a good microfiber cloth combined with a mild glass cleaner. Some people use foam cleaners, but for me, they can be a bit too harsh – better not to irritate the glass unnecessarily. I also like to use a small window squeegee; it helps dry the surface faster and leaves no streaks. Those little fingerprints become almost invisible. Honestly, it really saves time and is fun – like a mini window-cleaning party in the kitchen! 😄 A small tip: avoid using abrasive sponges, as they can cause scratches. Good luck with the cleaning!
Joe52
30 May 2024 10:03
Thanks for the question, Minjesper, I’m very familiar with that issue. Glass facades look great but do require regular maintenance. I occasionally use a spray bottle with a homemade cleaning solution — vinegar and water mixed in a 1:3 ratio — which works really well against limescale without damaging the material. It’s important to wipe them afterward with a dry cloth to avoid streaks. I often find it challenging to get the glass fronts spotless without streaks, so I appreciate any tips or new tools!
MOMIRA
30 May 2024 10:40
I recommend a soft, lint-free microfiber sponge and an alcohol-free glass cleaner. Do not use abrasive sponges or scouring agents.
PeoDaniel
30 May 2024 11:25
Hello Minjesper, I completely understand your concerns, as glass fronts do require a bit more care than regular surfaces. Regarding the tools: microfiber cloths are the best choice since they are lint-free and gentle. Additionally, use a spray cleaner for glass that does not contain harsh substances like ammonia or alcohol, to avoid damaging the sealant. For stubborn stains, a soft, damp sponge can be used, but without abrasive cleaners. In my opinion, a small window squeegee is often undervalued, especially for large glass fronts, as it helps with drying and reduces streaks. Overall, you should avoid applying too much pressure to prevent scratches. When cleaning the edges of the glass fronts, a cotton swab can be helpful in removing dirt from the corners.
Lucien
30 May 2024 12:47
From a technical perspective, Ikea Metod glass fronts are generally made of tempered glass, sometimes coated. For cleaning, the following tools and methods are recommended: - Microfiber cloths with high fiber density for streak-free cleaning - Glass cleaners without aggressive solvents such as ammonia or alcohol to avoid damaging the coating and adhesive - Plastic or silicone sponges that do not scratch - Squeegees for larger surfaces to prevent drips and streaks - Optional spray bottles with a water-vinegar mixture (1:3), useful against limescale and greasy fingerprints Do not use rigid or abrasive tools like steel wool or coarse sponges. Alcohol-based cleaners should also be avoided, as they can damage the adhesive seam over time. Regular cleaning helps to prolong the lifespan and maintain the appearance of the fronts.
