I am planning to assemble several Malm furniture pieces myself soon. I am wondering which tools are really useful to make the assembly more efficient and less frustrating. I have seen that an Allen wrench is often included, but is that enough? Or are there specific tools that help make the process easier—such as a cordless drill, special screwdriver bits, or particular pullers for dowels? I am especially interested in tips on how to avoid common mistakes and whether certain tools can noticeably speed up the process. What tools have you found helpful when assembling Malm furniture that you would recommend to beginners? Thanks in advance!
Hello koli39,
I can share a well-structured tool guide for Malm furniture based on my own experience.
1. Allen keys: These are included but often of low quality and uncomfortable to use. I prefer a small set of good-quality hex keys. This saves time and frustration.
2. Cordless drill/driver: Highly recommended, but use it carefully. Set a low torque to avoid over-tightening screws or damaging the wood.
3. Phillips screwdriver (PH2): Often easier to control by hand when tightening parts, compared to the cordless driver.
4. Rubber mallet: Perfect for gently positioning wooden dowels without damaging the surface.
5. Small pliers or needle-nose pliers: Useful when dowels or screws are difficult to grip.
Common mistake: Tightening screws too much before all parts are properly aligned – it’s better to assemble loosely first and then tighten.
Overall, a decent cordless drill with torque adjustment and a good screwdriver make the assembly much easier. Good luck!
First of all, a big compliment to Nabla64 for the very well-structured overview!
I would like to point out some technical details that are often underestimated when assembling Malm furniture:
The assembly of Malm dressers and similar furniture often relies on joining techniques using wooden or plastic dowels and cam lock screws. Especially with cam locks, it is important to use the appropriate screwdriver bit (usually a large Phillips, PH2) together with a reliable torque clutch to avoid stripping the threads.
It is also important that the holes for dowels and screws are cleanly chiseled out. A small chisel or edge planer can help remove minor protrusions to ensure precise fitting of the joints.
Using a small spirit level and tape measure during assembly helps to align the furniture properly. Uneven floors can cause Malm dressers to wobble easily.
Finally, my tip: keep a magnetic screw holder or a small parts tray handy. It’s easy to lose track of the many small screws and dowels—using a magnet as a “tool assistant” lets you work more efficiently without constantly dropping parts.
If you tell me exactly which Malm furniture you are assembling, I can offer more specific tips.
Hey, great topic here! 😊
I was pretty new the first time I assembled a Malm, and I realized that good lighting and a relaxed atmosphere are half the battle – not exactly a tool, but definitely essential for me 😉
As for the right tools: a cordless drill with adjustable torque control is the key! I got a small, handy one with an LED light so I can work even in poorly lit corners.
What really helps is a small clip you can attach to your belt to keep screws and small parts within reach – it really saves walking back and forth and frustration. And of course, the rubber mallet is great for the wall plugs, as Nabla64 already mentioned.
You should also have a Phillips screwdriver as a backup in case the cordless drill suddenly stops working – sometimes it’s just more comfortable to screw manually! 😉
Good luck with the assembly – you’ve got this! 😊
Interesting thread here, but I’d like to raise a somewhat controversial point:
Honestly – who actually works with such wood-unfriendly settings? It seems almost like overkill when you can slowly and carefully screw the screws in by hand. In my opinion, most users overestimate these power tools.
Of course, the Allen key is often inconvenient, but I prefer to rely on the original screwdriver included in the set rather than a cordless drill to maintain better control.
And regarding the question about “special helpers”: too much technology just makes things more complicated. There’s a much greater chance of errors – and I would argue that you also lose the tactile feeling for assembly.
Maybe it’s because of my preference for manual work, but in my view, anyone who assembles flat-pack furniture only with machines misses out on the real fun.
What do you think?
Nabla64 schrieb:
Cordless screwdriver with low torque setting to avoid damaging the wood
What do you think?
